Blender Import problems with MH plugin
Postby SaltyCowdawg » Wed Dec 11, 2019 3:55 pm
I just ran into a strange case with one of my models.
Raabi'a -- one of the denizens of Star City
When I try to use the MH plugin for Blender it fails and spews. Spew follows.
Read prefs: /home/peter/.config/blender/2.81/config/userpref.blend
found bundled python: /home/peter/apps/blender-2.81-linux-glibc217-x86_64/2.81/python
Loading MH community plug-in v 0.6.2
Loading sync plug-in
sync plug-in loaded
Loading kinect Sensor plug-in
kinect Sensor plug-in loaded
MH community plug-in load complete
/home/peter/.config/blender/2.81/makehuman.default.settings.json
Registered Carver
register
  File "/home/peter/.config/blender/2.81/scripts/addons/NodeCustomBuilder/__init__.py", line 259, in execute
    material = bpy.context.object.active_material
AttributeError: 'NoneType' object has no attribute 'active_material'
location: /home/peter/apps/blender-2.81-linux-glibc217-x86_64/2.81/scripts/modules/bpy/ops.py:201
Error: Traceback (most recent call last):
  File "/home/peter/.config/blender/2.81/scripts/addons/NodeCustomBuilder/__init__.py", line 68, in handler
    bpy.ops.custom.blend_select()
  File "/home/peter/apps/blender-2.81-linux-glibc217-x86_64/2.81/scripts/modules/bpy/ops.py", line 201, in __call__
    ret = op_call(self.idname_py(), None, kw)
RuntimeError: Error: Traceback (most recent call last):
  File "/home/peter/.config/blender/2.81/scripts/addons/NodeCustomBuilder/__init__.py", line 73, in init_handler
Import body
  File "/home/peter/.config/blender/2.81/scripts/addons/MH_Community/operators/bodyimport.py", line 14, in execute
    ImportBodyBinary()
  File "/home/peter/.config/blender/2.81/scripts/addons/MH_Community/mh_sync/import_body_binary.py", line 84, in __init__
    FetchServerData('getBodyMeshInfo', self.gotBodyInfo)
  File "/home/peter/.config/blender/2.81/scripts/addons/MH_Community/mh_sync/fetch_server_data.py", line 8, in __init__
    self.executeJsonCall(expectBinaryResponse=expectBinary, params=params)
  File "/home/peter/.config/blender/2.81/scripts/addons/MH_Community/mh_sync/sync_ops.py", line 17, in executeJsonCall
    json_obj = self.call.send(host=bpy.context.scene.MhHost, port=bpy.context.scene.MhPort, expectBinaryResponse=expectBinaryResponse)
  File "/home/peter/.config/blender/2.81/scripts/addons/MH_Community/mh_sync/JsonCall.py", line 224, in send
    data = JsonCall(data)
  File "/home/peter/.config/blender/2.81/scripts/addons/MH_Community/mh_sync/JsonCall.py", line 31, in __init__
    self.initializeFromJson(jsonData)
  File "/home/peter/.config/blender/2.81/scripts/addons/MH_Community/mh_sync/JsonCall.py", line 43, in initializeFromJson
    j = json.loads(jsonData)
  File "/home/peter/apps/blender-2.81-linux-glibc217-x86_64/2.81/python/lib/python3.7/json/__init__.py", line 348, in loads
    return _default_decoder.decode(s)
  File "/home/peter/apps/blender-2.81-linux-glibc217-x86_64/2.81/python/lib/python3.7/json/decoder.py", line 337, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/home/peter/apps/blender-2.81-linux-glibc217-x86_64/2.81/python/lib/python3.7/json/decoder.py", line 353, in raw_decode
    obj, end = self.scan_once(s, idx)
json.decoder.JSONDecodeError: Invalid control character at: line 8 column 16 (char 95)
I had thought the problem might be the glottal stop in her name so I took it out and resaved her. Still the plugin doesn't like this model for some reason. Can't understand why she's a nice girl... maybe not one you'd bring home to momma but a nice girl none-the-less. ;)
Found it!
Postby SaltyCowdawg » Wed Dec 11, 2019 3:59 pm
<sigh!>
Seems there was a trailing space in both the filename she was saved to and in the metadata. Removed the trailing space and it fixed the problem.
Shheeesh... I get myself into trouble easily these days....
Re: Blender Import problems with MH plugin
Postby loki1950 » Wed Dec 11, 2019 6:01 pm
No you just forget that computers are very anal retentive ;) if there is a nit to pick it comes to fore but with no real explanation.
Postby SaltyCowdawg » Wed Dec 11, 2019 6:04 pm
I would have thought (and I don't mean this to criticize) is some kind of format checking would be done before writing the JSON file. I know that code I've written in the past was OCD enough to check for gotchas like that, but then again even I missed that sometimes when writing code. I was blessed (cursed?) to have a tester that found problems like that very quickly. He could break code in ways I never would have thought about.
Postby loki1950 » Wed Dec 11, 2019 6:18 pm
Java Script is a bit minimalist when it comes to it's parsing functions most implementations have to be embedded in web browsers so the pressure to keep it simple is great.
