MH 1.2 alpha 3 doesn't start
Postby luis.gigi » Sun Sep 15, 2019 2:47 pm
Hallo,
It is the first time that I would like to use the MakeHuman in combination with Blender.
So I have installed the the version in subject on an Asus laptop windows 10 Home Cre i7, Geforce 940MX, 12 GB of memory.
The installation was ok, all files have been extracted on the directory that I choosed (C:\MakeHuman123, very simple.
When I do double click on the makehuman-comuniti program link nothing happen. Inside he link : C:\MakeHuman123\Python\pythonw.exe --noshaders "C:\MakeHuman123\mhstartwrapper.py"
anyway look like that nothing happen.
I tried to run as administrator and after I select yes, again, nothing happen
I have also add the pythonw and python inside Geforge.... (also tried with --noshaders)
At this point I don't know what to do.... If you can help me I appreciate... thanks.
luis.gigi
Re: MH 1.2 alpha 3 doesn't start
Postby joepal » Sun Sep 15, 2019 3:53 pm
Postby luis.gigi » Sun Sep 15, 2019 4:37 pm
I found this one, is it enough?
[2019-09-15 15:57:17,204] log.py->message():118 -- MESSAGE -- Initialized logging
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- VERSION: 1.2.0 Alpha3
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- HG REVISION: UNKNOWN
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- SHORT VERSION: alpha3
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- BASEMESH VERSION: hm08
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- IS BUILT (FROZEN): No
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- IS RELEASE VERSION: Yes
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- DEFAULT ENCODING: utf-8
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- FILESYSTEM ENCODING: utf-8
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- STDOUT ENCODING: cp1252
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- LOCALE PREFERRED ENCODING: cp1252
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- WORKING DIRECTORY: C:\MakeHuman123\makehuman
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- HOME LOCATION: C:/Users/luisg/Documents
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- PYTHON PATH: ./;./lib;./apps;./shared;./apps/gui;./core;C:\MakeHuman123\Python\python36.zip;C:\MakeHuman123\Python;C:\MakeHuman123\pkgs
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- DLL PATH: C:\Users\luisg\AppData\Local\Programs\Python\Python36-32\Scripts\;C:\Users\luisg\AppData\Local\Programs\Python\Python36-32\;C:\Users\luisg\AppData\Local\Microsoft\WindowsApps;
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- SYS.VERSION: 3.6.5 (v3.6.5:f59c0932b4, Mar 28 2018, 16:07:46) [MSC v.1900 32 bit (Intel)]
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- SYS.PLATFORM: win32
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- SYS.EXECUTABLE: C:\MakeHuman123\Python\pythonw.exe
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- PLATFORM.MACHINE: AMD64
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- PLATFORM.PROCESSOR: Intel64 Family 6 Model 142 Stepping 9, GenuineIntel
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- PLATFORM.UNAME.RELEASE: 10
[2019-09-15 15:57:17,220] log.py->debug():97 -- DEBUG -- PLATFORM.WIN32_VER: 10 10.0.17763 SP0 Multiprocessor Free
[2019-09-15 15:57:17,392] log.py->debug():97 -- DEBUG -- NUMPY.VERSION: 1.13.3
[2019-09-15 15:57:17,454] acceleratesupport.py-><module>():17 -- MESSAGE -- No OpenGL_accelerate module loaded: No module named 'OpenGL_accelerate'
[2019-09-15 15:57:18,228] log.py->debug():97 -- DEBUG -- QT.VERSION: 5.10.1
[2019-09-15 15:57:18,236] log.py->debug():97 -- DEBUG -- QT.JPG_SUPPORT: not supported
[2019-09-15 15:57:18,236] log.py->debug():97 -- DEBUG -- QT.SVG_SUPPORT: not supported
[2019-09-15 15:57:18,236] log.py->debug():97 -- DEBUG -- QT.PLUGIN_PATH: C:/MakeHuman123/pkgs/PyQt5/Qt/plugins;C:/MakeHuman123/Python
[2019-09-15 15:57:18,236] log.py->debug():97 -- DEBUG -- QT.PLUGIN_PATH_ENV:
[2019-09-15 15:57:18,236] log.py->debug():97 -- DEBUG -- QT.CONF: NOT PRESENT
luis.gigi
Postby luis.gigi » Sun Sep 15, 2019 5:24 pm
I have tried to use a 3.6 version of python and this is the result:
makehuman.txt:
[2019-09-15 19:15:26,136] log.py->message():118 -- MESSAGE -- Initialized logging
[2019-09-15 19:15:26,151] log.py->debug():97 -- DEBUG -- VERSION: 1.2.0 Alpha3
[2019-09-15 19:15:26,151] log.py->debug():97 -- DEBUG -- HG REVISION: UNKNOWN
[2019-09-15 19:15:26,151] log.py->debug():97 -- DEBUG -- SHORT VERSION: alpha3
[2019-09-15 19:15:26,151] log.py->debug():97 -- DEBUG -- BASEMESH VERSION: hm08
[2019-09-15 19:15:26,151] log.py->debug():97 -- DEBUG -- IS BUILT (FROZEN): No
[2019-09-15 19:15:26,151] log.py->debug():97 -- DEBUG -- IS RELEASE VERSION: Yes
[2019-09-15 19:15:26,151] log.py->debug():97 -- DEBUG -- DEFAULT ENCODING: utf-8
[2019-09-15 19:15:26,151] log.py->debug():97 -- DEBUG -- FILESYSTEM ENCODING: utf-8
[2019-09-15 19:15:26,151] log.py->debug():97 -- DEBUG -- STDOUT ENCODING: cp1252
[2019-09-15 19:15:26,151] log.py->debug():97 -- DEBUG -- LOCALE PREFERRED ENCODING: cp1252
[2019-09-15 19:15:26,151] log.py->debug():97 -- DEBUG -- WORKING DIRECTORY: C:\MakeHuman123\makehuman
[2019-09-15 19:15:26,151] log.py->debug():97 -- DEBUG -- HOME LOCATION: C:/Users/luisg/Documents
[2019-09-15 19:15:26,151] log.py->debug():97 -- DEBUG -- PYTHON PATH: ./;./lib;./apps;./shared;./apps/gui;./core;C:\MakeHuman123\makehuman;C:\Users\luisg\AppData\Local\Programs\Python\Python36-32\python36.zip;C:\Users\luisg\AppData\Local\Programs\Python\Python36-32\DLLs;C:\Users\luisg\AppData\Local\Programs\Python\Python36-32\lib;C:\Users\luisg\AppData\Local\Programs\Python\Python36-32;C:\Users\luisg\AppData\Local\Programs\Python\Python36-32\lib\site-packages
[2019-09-15 19:15:26,151] log.py->error():111 -- ERROR -- Could not create debug dump
File "makehuman.py", line 203, in debug_dump
debugdump.dump.reset()
File "./lib\debugdump.py", line 121, in reset
self.write("DLL PATH: %s", getpath.pathToUnicode(os.environ['PATH']))
File "C:\Users\luisg\AppData\Local\Programs\Python\Python36-32\lib\os.py", line 669, in __getitem__
raise KeyError(key) from None
KeyError: 'PATH'
Python_err.txt:
Initialized logging
KeyError: 'PATH'
File "makehuman.py", line 613, in <module>
main()
File "makehuman.py", line 598, in main
import numpy
ModuleNotFoundError: No module named 'numpy'
I forced the Geforce to use Opengl and I have tested with the application opengl extension viewer 5.1
The gforce is working with opengl so at this point really I don't know what happen....
luis.gigi
Postby joepal » Mon Sep 16, 2019 3:51 pm
I don't see any obvious problem in the first log. But that's not uncommon, since it crashes before being able to log the problem.
In the second log, it seems you have not run "pip install numpy" from a dos prompt. If you take a look at http://www.makehumancommunity.org/wiki/ ... _source%3F (the "running from source on windows" section), you can see three dependencies listed. If you run those commands, it should be enough to make MH start from source. Well, unless it crashes due to the original problem of course.
Postby Aranuvir » Tue Sep 17, 2019 6:33 am
There's a KeyError for os.environ['PATH']. Looks more like Python is not setup correctly?
Postby luis.gigi » Wed Sep 18, 2019 9:28 pm
sorry, but python should be installed automatically by the installation, or not?
luis.gigi
