Runtime error
Runtime error
Postby joepal » Sat Jun 21, 2008 1:52 pm
You probably know already, but wth, there's a bug forum.. :)
Latest svn (505) throws up the following and refuses to start:
time to build mesh:  0.485235929489
  File "<string>", line 1, in ?
  File "main.py", line 154, in ?
    loadMesh("3dobjs/base.obj")
  File "main.py", line 132, in loadMesh
    loadVertsColors(ob, None)
NameError: global name 'loadVertsColors' is not defined
numero oggetti 0
Re: Runtime error
Postby Manuel » Mon Jun 23, 2008 9:54 am
fixed. Can you try last svn?
Re: Runtime error
Postby joepal » Tue Jun 24, 2008 8:28 am
Problem remains in revision 508, but now a new error message is listed at the top too:
Warning: obj 3dobjs/base.obj has 1 facegroups but only 0 are named
object name  base.obj
time to build mesh:  0.518851995468
  File "main.py", line 167, in ?
  File "main.py", line 145, in loadMesh
    loadVertsColors(ob, colorPath, None)
numero oggetti 0
Re: Runtime error
Postby Manuel » Tue Jul 01, 2008 10:15 am
Ah ok.
It's not a real bug.
You must delete all *.pyc, because now pyhton files are in mh_core folder, but if you have old pyc in main folder, they are used instead.
Ciao,
