Installing in Ubuntu Problem
Postby Madness3D » Fri Apr 19, 2019 7:35 pm
ubuntu-18.04.2-desktop-amd64.iso on a Micro-SD card with persistence
404 Not Found [IP: 91.189.95.83 80]
Reading package lists... Done
E: The repository 'http://ppa.launchpad.net/makehuman-official/makehuman-11x/ubuntu bionic Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
What it says in terminal.
Thanks.
Madness3D
Re: Installing in Ubuntu Problem
Postby Aranuvir » Fri Apr 19, 2019 8:21 pm
Probably I've missed the question? So I can only guess. As you pointed out the terminal is telling you the problem:
There is no 11x build for bionic. You should either try this ppa: https://launchpad.net/~makehuman-offici ... -community or run from source...
