SOLVED: Ubuntu bionic
Postby grinsegold » Wed Jan 09, 2019 4:55 pm
Hi, i tried to add the PPA for Makehuman on Linux, but here's what my Linux Mint 19 says:
sudo add-apt-repository ppa:makehuman-official/makehuman-11x
HTTP Error 404: Not Found
PPA kann nicht hinzugefügt werden: »'Dieses PPA unterstützt bionic nicht'«.
The last line is german and says: PPA can't be added: "This PPA dooesn't support bionic".
Maybe this is a known issue? I couldn't find a search result here. Thanks in advance.
grinsegold
Re: Ubuntu bionic
Postby Aranuvir » Wed Jan 09, 2019 6:04 pm
Re: Ubuntu bionic
Postby wolgade » Wed Jan 09, 2019 7:39 pm
grinsegold wrote:ppa:makehuman-official/makehuman-11x
This ppa probably doesn't exist anymore.
Aranuvir wrote:http://www.makehumancommunity.org/wiki/ ... 0a2#Ubuntu
You're suggesting Alpha 1.2. That's not what grinsegold is looking for.
Re: Ubuntu bionic
Postby Aranuvir » Wed Jan 09, 2019 8:51 pm
I didn't know, we ever had a 1.1.X build for Bionic (though I might be wrong here). If you want to use the PPA for Bionic, you'll have to use the development version, otherwise run from source code. That shouldn't be a big deal on Linux.
Re: Ubuntu bionic
Postby joepal » Wed Jan 09, 2019 9:35 pm
It's a known issue. The message is correct: The 11x PPA exists, but doesn't support Bionic, as the build there doesn't work with the numpy in Bionic.
Your options are to run MakeHuman from source, see http://www.makehumancommunity.org/wiki/ ... _source%3F, or to give the 12x PPA a try.
Re: Ubuntu bionic
Postby grinsegold » Thu Jan 10, 2019 10:03 pm
grinsegold
Re: Ubuntu bionic
Postby grinsegold » Sat Jan 12, 2019 8:44 am
joepal wrote:...or to give the 12x PPA a try.
I did that, but now i can't find a makehuman button anywhere in my start menu. How do i start makehuman? Also i have error messages after doing the step that's recommended for Mint-users:
"sudo apt-get install makehuman-community-plugins-socket makehuman-community-plugins-assetdownloader mhx2-makehuman-exchange
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
E: Paket makehuman-community-plugins-socket kann nicht gefunden werden.
E: Paket makehuman-community-plugins-assetdownloader kann nicht gefunden werden.
E: Paket mhx2-makehuman-exchange kann nicht gefunden werden."
In the last 3 lines it tells me that ...-socket, ...-assetdownloader and mhx2-makehuman-exchange can't be found. Sorry if these are stupid questions.
grinsegold
Re: Ubuntu bionic
Postby joepal » Sat Jan 12, 2019 12:00 pm
Hm, it looks as if something is wrong here. Can you run the following and paste the output here?
sudo apt-get update && apt-cache search makehuman
Re: Ubuntu bionic
Postby grinsegold » Sat Jan 12, 2019 2:19 pm
joepal wrote:... paste the output here?
apt-cache search makehuman.txt
(1.67 KiB) Downloaded 149 times
grinsegold
Re: Ubuntu bionic
Postby joepal » Sat Jan 12, 2019 3:27 pm
Looks fine to me. Only thing I can think of is you didn't run "apt-get update" before trying to install the packages. Can you try again and see if it works now?
