Page 1 of 2
1.2.0 alpha1 is empty when started
PostPosted: Thu Nov 29, 2018 12:33 pm
by tiku_67
When I start MakeHuman 1.2.0 it is blank, i.e. there is no base model to start modeling with. How can I fix this?
Re: 1.2.0 alpha1 is empty when started
PostPosted: Thu Nov 29, 2018 1:16 pm
by MargaretToigo
It is for me, too. It's got something to do with OpenGl. There's another thread about it here...
http://www.makehumancommunity.org/forum/viewtopic.php?f=15&t=16844
PostPosted: Thu Nov 29, 2018 1:42 pm
Yes, this is the known issue (http://www.makehumancommunity.org/wiki/ ... own_issues) that on some graphics cards, no visible output is produced.
If you have a computer with a different graphics card, you can try that. Otherwise, we're aware of the problem and will try to fix this before a stable release.
PostPosted: Fri Nov 30, 2018 12:08 am
by RobBaer
tiku_67 wrote:Hi,
Would you mind sharing what operating system and graphics card this was on? Windows? MacOS? AMD or Intel? Model? Any detail would help. Also, if you can and are willing, attaching you makehuman.log file could help us understand exactly who is at risk.
In my case, I have one Mac running Mohave (and previously running High Sierra) that has this problem. It has both NVidea and Intel graphics. Margaret, if I understood properly, was Windows 10 and AMD graphics. On the other hand I have some Windows 10 Intel/NVidea machines that are doing well so far.
PostPosted: Fri Nov 30, 2018 12:53 pm
by MargaretToigo
Yes, Windows 10 and AMD graphics.
PostPosted: Thu Dec 13, 2018 12:00 pm
by tiku_67
MargaretToigo wrote:Yes, Windows 10 and AMD graphics.
I also have same setup. AMD A8-7410 APU with AMD Radeon R5 Graphics + Radeon R7 M340. Windows build is 17134.471
PostPosted: Tue Dec 25, 2018 6:31 pm
by nzayem
I downloaded the 1.2.0 alpha and facing the same issue with AMD RADEON R5 M335, Windows 10, i am getting a white workspace,,,
i had also another issue when switching to the Intel HD graphic, where the program cannot start or load,,, Running it as an administrator gives me an error in the splash screen [Exception during event onStart].
i am using already the 1.1.1 version on the same laptop without any issue,,, hope this could be fixed soon,, :roll: :roll:
PostPosted: Thu Jan 03, 2019 9:51 am
by loki1950
Basically the same issue I will be attaching the full log as well as the abstracted relevant section in
 tags
System info
[code][2019-01-03 04:27:07,193] log.py->message():134 -- MESSAGE -- Initialized logging
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- VERSION: 1.2.0
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- HG REVISION: UNKNOWN
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- SHORT VERSION: v1.2.0
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- BASEMESH VERSION: hm08
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- IS BUILT (FROZEN): No
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- IS RELEASE VERSION: Yes
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- DEFAULT ENCODING: utf-8
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- FILESYSTEM ENCODING: utf-8
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- STDOUT ENCODING: cp1252
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- WORKING DIRECTORY: C:\Program Files (x86)\makehuman-community\makehuman
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- HOME LOCATION: C:/Users/denis/OneDrive/Documents
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- PYTHON PATH: ./;./lib;./apps;./shared;./apps/gui;./core;C:\Program Files (x86)\makehuman-community\Python\python36.zip;C:\Program Files (x86)\makehuman-community\Python;C:\Program Files (x86)\makehuman-community\pkgs
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- DLL PATH: C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Users\denis\AppData\Local\Microsoft\WindowsApps;
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- SYS.VERSION: 3.6.5 (v3.6.5:f59c0932b4, Mar 28 2018, 16:07:46) [MSC v.1900 32 bit (Intel)]
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- SYS.PLATFORM: win32
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- SYS.EXECUTABLE: C:\Program Files (x86)\makehuman-community\Python\pythonw.exe
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- PLATFORM.MACHINE: AMD64
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- PLATFORM.PROCESSOR: AMD64 Family 21 Model 101 Stepping 1, AuthenticAMD
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- PLATFORM.UNAME.RELEASE: 10
[2019-01-03 04:27:07,224] log.py->debug():113 -- DEBUG -- PLATFORM.WIN32_VER: 10 10.0.16299 SP0 Multiprocessor Free
[2019-01-03 04:27:13,761] log.py->debug():113 -- DEBUG -- NUMPY.VERSION: 1.13.3
[2019-01-03 04:27:13,870] acceleratesupport.py-><module>():17 -- MESSAGE -- No OpenGL_accelerate module loaded: No module named 'OpenGL_accelerate'
[2019-01-03 04:27:24,043] log.py->debug():113 -- DEBUG -- QT.VERSION: 5.10.1
[2019-01-03 04:27:25,025] log.py->debug():113 -- DEBUG -- QT.JPG_SUPPORT: not supported
[2019-01-03 04:27:25,025] log.py->debug():113 -- DEBUG -- QT.SVG_SUPPORT: not supported
[2019-01-03 04:27:25,025] log.py->debug():113 -- DEBUG -- QT.PLUGIN_PATH: C:/Program Files (x86)/makehuman-community/pkgs/PyQt5/Qt/plugins;C:/Program Files (x86)/makehuman-community/Python
[2019-01-03 04:27:25,025] log.py->debug():113 -- DEBUG -- QT.PLUGIN_PATH_ENV:
[2019-01-03 04:27:25,025] log.py->debug():113 -- DEBUG -- QT.CONF: NOT PRESENT
[2019-01-03 04:27:26,499] log.py->debug():113 -- DEBUG -- PYOPENGL.VERSION: 3.1.0
[2019-01-03 04:27:26,499] log.py->debug():113 -- DEBUG -- GL.VENDOR: ATI Technologies Inc.
[2019-01-03 04:27:26,499] log.py->debug():113 -- DEBUG -- GL.RENDERER: AMD Radeon R7 Graphics
[2019-01-03 04:27:26,499] log.py->debug():113 -- DEBUG -- GL.VERSION: 4.5.13476 Compatibility Profile Context 22.19.180.1536
[2019-01-03 04:27:26,499] log.py->debug():113 -- DEBUG -- 4.50
[2019-01-03 04:27:26,499] log.py->debug():113 -- DEBUG -- GLSL.VERSION: 4.50
[2019-01-03 04:27:26,499] log.py->debug():113 -- DEBUG -- GL.EXTENSION: GL_ARB_multisample enabled (4x samples)
[2019-01-03 04:27:26,514] log.py->debug():113 -- DEBUG -- Creating new texture for image data/textures/texture_notfound.png.
[2019-01-03 04:27:26,514] log.py->debug():113 -- DEBUG -- GL.EXTENSION: GL_ARB_texture_non_power_of_two enabled
[2019-01-03 04:27:26,514] log.py->debug():113 -- DEBUG -- initTexture: 256, 256, False
[2019-01-03 04:27:26,577] log.py->debug():113 -- DEBUG -- Setting language to english
[2019-01-03 04:27:26,577] log.py->warning():120 -- WARNING -- No settings file found, starting with default settings.
[2019-01-03 04:27:26,577] log.py->warning():120 -- WARNING -- shortcuts.ini out of date; ignoring
[2019-01-03 04:27:26,577] log.py->message():134 -- MESSAGE -- Initializing default theme first.
[2019-01-03 04:27:26,577] log.py->message():134 -- MESSAGE -- Theme default version 1.1.0
[2019-01-03 04:27:26,593] log.py->debug():113 -- DEBUG -- Loaded theme data/themes/default.mht
[2019-01-03 04:27:26,593] log.py->debug():113 -- DEBUG -- Using Qt system style windowsvista[/code]
Tracebacks
[code]Traceback (most recent call last):
  File "./lib\glmodule.py", line 1038, in draw
    _draw(productionRender)
  File "./lib\glmodule.py", line 1030, in _draw
    drawMeshes(False, productionRender)
  File "./lib\glmodule.py", line 1026, in drawMeshes
    drawOrPick(pickMode, obj)
  File "./lib\glmodule.py", line 671, in drawOrPick
    obj.draw()
  File "./lib\object3d.py", line 286, in draw
    return glmodule.drawMesh(self, *args, **kwargs)
  File "./lib\glmodule.py", line 421, in drawMesh
    glPushMatrix()
  File "C:\Program Files (x86)\makehuman-community\pkgs\OpenGL\error.py", line 232, in glCheckError
    baseOperation = baseOperation,
OpenGL.error.GLError: GLError(
   err = 1283,
   description = b'stack overflow',
   baseOperation = glPushMatrix,
   cArguments = ()
[2019-01-03 04:31:32,983] log.py->error():127 -- ERROR -- gl.draw
    obj.draw()
    glPushMatrix()
   err = 1283,
   cArguments = ()
[2019-01-03 04:31:43,003] log.py->error():127 -- ERROR -- gl.draw
    obj.draw()
    glPushMatrix()
   err = 1283,
   cArguments = ()
[2019-01-03 04:31:43,206] log.py->error():127 -- ERROR -- gl.draw
    obj.draw()
    glPushMatrix()
   err = 1283,
   cArguments = ()
[2019-01-03 04:32:18,699] log.py->error():127 -- ERROR -- gl.draw
    obj.draw()
    glPushMatrix()
   err = 1283,
   cArguments = ()
[2019-01-03 04:32:25,962] log.py->error():127 -- ERROR -- gl.draw
    obj.draw()
    glPushMatrix()
   err = 1283,
   cArguments = ()
[2019-01-03 04:32:36,604] log.py->error():127 -- ERROR -- gl.draw
    obj.draw()
    glPushMatrix()
   err = 1283,
   cArguments = ()
makehuman.log
(67.74 KiB) Downloaded 1212 times
PostPosted: Thu Jan 17, 2019 11:15 am
by needlessOne
Same issue in Alpha 2. Windows 10 AMD RX 560 with latest drivers. I also can't even use makehuman 1.1.1. When I try to run it I get "Fatal Error! Failed to execute script __init__"
So now I'm left with no working makehuman version in a time I need it.
PostPosted: Tue Jan 22, 2019 11:52 pm
by mr_tawan
I've got the same issue (Windows 10 1809 x64, Radeon Software 19.1.1, Core i7 4790, AMD Radeon RX480 8GB).
As I'm curios what was going on, I've cloned the code and play with it a little bit. So far with the latest master (1.2.0 master:65278992), the issue still persists. I play with it a little bit further, by just commenting out some code that cause the error in the log file. Below are the code that I commented out.
glmodule.py - line #452 and #454
                # glDisable(GL_TEXTURE_2D)
                glBindTexture(GL_TEXTURE_1D, 0)
                # glDisable(GL_TEXTURE_1D)
shader.py - line #485 and #487
And then it works! :D :D Well I don't know why (classics, isn't it?).
Anyway I can't say this is a permanent fix for the issue, I don't know why it works after all. I think the code was there for a reason. Unfortunately I'm no OpenGL expert. I've seen some comments saying that if you're using shader, these are not needed. One more problem is the error in the log says "error code 1281 - invalid values", which I don't see listed in the Khronos Group's API documentation. I guess the developers/maintainers might want to talk with some AMD people to see why this return code is returned.
Also It works on my machine/setup, it might not work for anybody elese. I can't say for sure because I only have one AMD system. It might cause problems in non-AMD systeam as well.
That's all my findings. Hope this might helps!
