You'll need to reapply the textures (and perhaps change the material type), all the textures are in the /data/rib_data/textures_data/ directory.
The material the imported mesh has is a Multi/Sub-object, each ID is a different part:
1-body - use the texture body_color.tif for diffuse color, body_specular.tif for spectacular color and body_bump.tif for the bump (or change the material type to SSS Fast Skin Material and use body_color.tif for overall diffuse coloration, the bump texture doesn't work to good with that so I suggest to use this normal map and tile it 12-20 times:
http://www.filterforge.com/filters/3551-normal.html)
2- eye - use: eyes_color.tif and eyes_reflection.tif (in the right slots of course) - you might toy a bit with glossiness and spectacular levels or change the material type to ray traced
3- head - use: head_color, head_bump and head_spectacular (or SSS Fast Skin Material like for the body)
4- teeth -???
5- tongue - ??? (head_color, head_bump and head_spectacular)
6 - iris - ??? (eyes_reflection?)
7- eyebrows - eyebrows_color.tif (this one needs a alpha channel - I needed to make a black and with version of the texture to get it right)
8-eyelashes - eyelashes_color (with alpha - same as eyebrows )
Hope this helps.
(oh, and there's a "materials.mtl" file with every obj file, but that didn't work good enough for me, still had to reapply the textures)
