Ubuntu Linux & Asset downloader Plugin
Postby OBI_Ron » Wed Jul 18, 2018 11:38 pm
Hello Everyone,
I installed the latest MHAPI, Server Socket and asset downloader to /usr/share/makehuman/plugins. Everything works except the asset downloader.
I have tried completely un-installing and re-installing from PPA, and I get the same results.
Any ideas?
From the log file:
Could not load 8_asset_downloader
File "./core/mhmain.py", line 541, in loadPlugin
module.load(self)
File "plugins/8_asset_downloader/__init__.py", line 38, in load
downloadView = category.addTask(AssetDownloadTaskView(category))
File "plugins/8_asset_downloader/assetdownload.py", line 73, in __init__
self._setupFilterBox()
File "plugins/8_asset_downloader/assetdownload.py", line 104, in _setupFilterBox
self.filterBox.addWidget(self.cbxTypes)
File "./lib/qtgui.py", line 211, in addWidget
self.layout.addWidget(widget, row, column, rowSpan, columnSpan, alignment)
TypeError: arguments did not match any overloaded call:
QGridLayout.addWidget(QWidget): argument 1 has unexpected type 'ComboBox'
QGridLayout.addWidget(QWidget, int, int, Qt.Alignment alignment=0): argument 1 has unexpected type 'ComboBox'
QGridLayout.addWidget(QWidget, int, int, int, int, Qt.Alignment alignment=0): argument 1 has unexpected type 'ComboBox'
OBI_Ron
Re: Ubuntu Linux & Asset downloader Plugin
Postby Aranuvir » Thu Jul 19, 2018 6:39 am
I might be wrong, but it reminds me of some PyQt4 Pyside mismatch, I’ve seen some time ago, when we did some tests with alternatives for PyQt4. Can you check your package management system, if you have Pyside installed?
Postby OBI_Ron » Thu Jul 19, 2018 10:27 am
Aranuvir,
Thanks for the reply - I will check tonight and let you know.
OBI_Ron
Postby OBI_Ron » Thu Jul 19, 2018 9:23 pm
Hi Aranuvir,
No Luck - pyside was not installed, so I started with python 3 pydise - same error, then add python pyside and still got the same error.
module.load(self)
OBI_Ron
Postby Aranuvir » Fri Jul 20, 2018 8:25 am
Just for being precise: As far as I know, you cannot mix code that uses Pyside on the one and PyQt4 on the other hand. And if I get the code lines of the current asset downloader plugin correctly, it will automatically make use of Pyside if it is found (this behavior should be changed). That's why I was asking. Do not install it, if you don't need it.
Based on the plugins location I assume you are using the latest stable build of MakeHuman. This version will not run with Python3 anyway.
To track down the issues we need more info. Could you provide the makehuman.log? It's not necessary to upload the file, you cam also copy and paste as "code". And if you are concerned about your privacy, it's pretty fine to search and replace usernames by something more general like $USER or $HOME...
Postby OBI_Ron » Fri Jul 20, 2018 9:10 am
Hi Aranuvir,
Yes - latest stable build and plugin.
Here is the log file from $HOME/makehuman/v1
[2018-07-20 04:54:22,874] log.py->message():133 -- MESSAGE -- Initialized logging
[2018-07-20 04:54:22,941] log.py->debug():112 -- DEBUG -- VERSION: 1.1.1
[2018-07-20 04:54:22,941] log.py->debug():112 -- DEBUG -- HG REVISION: r2128 (2d119491670c) [data/VERSION static revision data]
[2018-07-20 04:54:22,941] log.py->debug():112 -- DEBUG -- SHORT VERSION: v1.1.1
[2018-07-20 04:54:22,941] log.py->debug():112 -- DEBUG -- BASEMESH VERSION: hm08
[2018-07-20 04:54:22,941] log.py->debug():112 -- DEBUG -- IS BUILT (FROZEN): No
[2018-07-20 04:54:22,941] log.py->debug():112 -- DEBUG -- IS RELEASE VERSION: Yes
[2018-07-20 04:54:22,941] log.py->debug():112 -- DEBUG -- DEFAULT ENCODING: utf-8
[2018-07-20 04:54:22,942] log.py->debug():112 -- DEBUG -- FILESYSTEM ENCODING: UTF-8
[2018-07-20 04:54:22,942] log.py->debug():112 -- DEBUG -- STDOUT ENCODING: UTF-8
[2018-07-20 04:54:22,942] log.py->debug():112 -- DEBUG -- WORKING DIRECTORY: /usr/share/makehuman
[2018-07-20 04:54:22,942] log.py->debug():112 -- DEBUG -- HOME LOCATION: /home/$HOME
[2018-07-20 04:54:22,942] log.py->debug():112 -- DEBUG -- PYTHON PATH: ./:./lib:./apps:./shared:./apps/gui:./core:/usr/share/makehuman:/usr/lib/python2.7:/usr/lib/python2.7/plat-x86_64-linux-gnu:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/home/obi-ron/.local/lib/python2.7/site-packages:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gtk-2.0:/usr/lib/python2.7/dist-packages/wx-3.0-gtk2
[2018-07-20 04:54:22,942] log.py->debug():112 -- DEBUG -- DLL PATH: /home/$HOME/bin:/home/$HOME/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
[2018-07-20 04:54:22,942] log.py->debug():112 -- DEBUG -- SYS.VERSION: 2.7.12 (default, Dec  4 2017, 14:50:18)  [GCC 5.4.0 20160609]
[2018-07-20 04:54:22,942] log.py->debug():112 -- DEBUG -- SYS.PLATFORM: linux2
[2018-07-20 04:54:22,942] log.py->debug():112 -- DEBUG -- SYS.EXECUTABLE: /usr/bin/python
[2018-07-20 04:54:22,945] log.py->debug():112 -- DEBUG -- PLATFORM.MACHINE: x86_64
[2018-07-20 04:54:22,945] log.py->debug():112 -- DEBUG -- PLATFORM.PROCESSOR: x86_64
[2018-07-20 04:54:22,946] log.py->debug():112 -- DEBUG -- PLATFORM.UNAME.RELEASE: 4.4.0-130-generic
[2018-07-20 04:54:22,946] log.py->debug():112 -- DEBUG -- PLATFORM.LINUX_DISTRIBUTION: Ubuntu 16.04 xenial
[2018-07-20 04:54:23,925] log.py->debug():112 -- DEBUG -- NUMPY.VERSION: 1.11.0
[2018-07-20 04:54:24,525] acceleratesupport.py-><module>():17 -- MESSAGE -- No OpenGL_accelerate module loaded: No module named OpenGL_accelerate
[2018-07-20 04:54:24,612] formathandler.py->loadPlugin():46 -- MESSAGE -- Unable to load registered array format handler numeric
[2018-07-20 04:54:24,615] formathandler.py->loadPlugin():46 -- MESSAGE -- Unable to load registered array format handler vbo
[2018-07-20 04:54:24,616] formathandler.py->loadPlugin():46 -- MESSAGE -- Unable to load registered array format handler vbooffset
[2018-07-20 04:54:27,317] log.py->debug():112 -- DEBUG -- PYQT.VERSION: 4.8.7
[2018-07-20 04:54:27,731] log.py->debug():112 -- DEBUG -- PYQT.JPG_SUPPORT: supported
[2018-07-20 04:54:27,732] log.py->debug():112 -- DEBUG -- PYQT.SVG_SUPPORT: supported
[2018-07-20 04:54:27,745] log.py->debug():112 -- DEBUG -- QT.PLUGIN_PATH: /usr/lib/kde4/plugins:/usr/lib/x86_64-linux-gnu/qt4/plugins:/usr/bin
[2018-07-20 04:54:27,745] log.py->debug():112 -- DEBUG -- QT.PLUGIN_PATH_ENV:
[2018-07-20 04:54:27,745] log.py->debug():112 -- DEBUG -- QT.CONF: NOT PRESENT
[2018-07-20 04:54:28,536] log.py->debug():112 -- DEBUG -- PYOPENGL.VERSION: 3.0.2
[2018-07-20 04:54:28,536] log.py->debug():112 -- DEBUG -- GL.VENDOR: NVIDIA Corporation
[2018-07-20 04:54:28,536] log.py->debug():112 -- DEBUG -- GL.RENDERER: GeForce GTX 1050 Ti/PCIe/SSE2
[2018-07-20 04:54:28,536] log.py->debug():112 -- DEBUG -- GL.VERSION: 4.5.0 NVIDIA 384.130
[2018-07-20 04:54:28,537] extensions.py->getGLVersion():92 -- DEBUG -- OpenGL Version: 4.5.0 NVIDIA 384.130
[2018-07-20 04:54:28,537] log.py->debug():112 -- DEBUG -- GLSL.VERSION: 4.50 NVIDIA
[2018-07-20 04:54:28,538] extensions.py->hasGLExtension():148 -- DEBUG -- GL Extension GL_ARB_multisample available
[2018-07-20 04:54:28,555] log.py->debug():112 -- DEBUG -- GL.EXTENSION: GL_ARB_multisample enabled (4x samples)
[2018-07-20 04:54:28,573] log.py->debug():112 -- DEBUG -- Creating new texture for image data/textures/texture_notfound.png.
[2018-07-20 04:54:28,612] extensions.py->hasGLExtension():148 -- DEBUG -- GL Extension GL_ARB_texture_non_power_of_two available
[2018-07-20 04:54:28,612] log.py->debug():112 -- DEBUG -- GL.EXTENSION: GL_ARB_texture_non_power_of_two enabled
[2018-07-20 04:54:28,649] log.py->debug():112 -- DEBUG -- initTexture: 256, 256, False
[2018-07-20 04:54:28,789] log.py->debug():112 -- DEBUG -- Setting language to english
[2018-07-20 04:54:28,826] log.py->debug():112 -- DEBUG -- Setting language to english
[2018-07-20 04:54:28,843] log.py->message():133 -- MESSAGE -- Initializing default theme first.
[2018-07-20 04:54:28,870] log.py->message():133 -- MESSAGE -- Theme default version 1.1.0
[2018-07-20 04:54:28,873] log.py->debug():112 -- DEBUG -- Loaded theme data/themes/default.mht
[2018-07-20 04:54:28,875] log.py->debug():112 -- DEBUG -- Using Qt system style gtk+
[2018-07-20 04:54:29,294] log.py->message():133 -- MESSAGE -- Loading human
[2018-07-20 04:54:29,323] log.py->debug():112 -- DEBUG -- Loading binary mesh data/3dobjs/base.npz.
[2018-07-20 04:54:29,559] log.py->debug():112 -- DEBUG -- Loading material from file data/skins/default.mhmat
[2018-07-20 04:54:29,618] log.py->debug():112 -- DEBUG -- Shader: adding built-in uniform gl_ModelViewProjectionMatrixTranspose
[2018-07-20 04:54:29,619] log.py->debug():112 -- DEBUG -- Shader: adding built-in uniform gl_NormalMatrix
[2018-07-20 04:54:29,991] log.py->message():133 -- MESSAGE -- Loaded vertex weights MakeHuman weights from file /usr/share/makehuman/data/rigs/default_weights.mhw
[2018-07-20 04:54:30,500] log.py->message():133 -- MESSAGE -- Loading scene
[2018-07-20 04:54:30,548] log.py->debug():112 -- DEBUG -- Loading scene file: data/scenes/default.mhscene
[2018-07-20 04:54:30,559] log.py->message():133 -- MESSAGE -- Loading main GUI
[2018-07-20 04:54:30,586] log.py->debug():112 -- DEBUG -- Assigning setting loaddir value /home/$HOME/makehuman/v1/models that was loaded before the setting was declared.
[2018-07-20 04:54:30,601] log.py->debug():112 -- DEBUG -- Assigning setting savedir value /home/$HOME/makehuman/v1/models that was loaded before the setting was declared.
[2018-07-20 04:54:30,604] log.py->debug():112 -- DEBUG -- Assigning setting exportdir value /home/$HOME/makehuman/v1/exports that was loaded before the setting was declared.
[2018-07-20 04:54:30,621] log.py->message():133 -- MESSAGE -- Loading plugins
[2018-07-20 04:54:30,728] log.py->message():133 -- MESSAGE -- Importing plugin 0_modeling_0_modifiers
[2018-07-20 04:54:30,770] log.py->message():133 -- MESSAGE -- Imported plugin 0_modeling_0_modifiers
[2018-07-20 04:54:30,773] log.py->message():133 -- MESSAGE -- Loading plugin 0_modeling_0_modifiers
[2018-07-20 04:54:30,777] log.py->debug():112 -- DEBUG -- Loading modifiers from data/modifiers/modeling_modifiers.json
[2018-07-20 04:54:30,805] log.py->debug():112 -- DEBUG -- Attempting to load targets from NPZ file.
[2018-07-20 04:54:31,535] log.py->debug():112 -- DEBUG -- 1258 targets loaded from NPZ file succesfully.
[2018-07-20 04:54:33,490] log.py->message():133 -- MESSAGE -- Loaded 249 modifiers from file data/modifiers/modeling_modifiers.json
[2018-07-20 04:54:33,514] log.py->message():133 -- MESSAGE -- Loaded 249 modifier descriptions from file data/modifiers/modeling_modifiers_desc.json
[2018-07-20 04:54:34,560] log.py->message():133 -- MESSAGE -- Loaded plugin 0_modeling_0_modifiers
[2018-07-20 04:54:34,614] log.py->message():133 -- MESSAGE -- Importing plugin 0_modeling_8_random
[2018-07-20 04:54:34,632] log.py->message():133 -- MESSAGE -- Imported plugin 0_modeling_8_random
[2018-07-20 04:54:34,634] log.py->message():133 -- MESSAGE -- Loading plugin 0_modeling_8_random
[2018-07-20 04:54:34,664] log.py->message():133 -- MESSAGE -- Loaded plugin 0_modeling_8_random
[2018-07-20 04:54:34,670] log.py->message():133 -- MESSAGE -- Importing plugin 0_modeling_9_custom_targets
[2018-07-20 04:54:34,684] log.py->message():133 -- MESSAGE -- Imported plugin 0_modeling_9_custom_targets
[2018-07-20 04:54:34,686] log.py->message():133 -- MESSAGE -- Loading plugin 0_modeling_9_custom_targets
[2018-07-20 04:54:34,718] log.py->message():133 -- MESSAGE -- Loaded plugin 0_modeling_9_custom_targets
[2018-07-20 04:54:34,724] log.py->message():133 -- MESSAGE -- Importing plugin 0_modeling_a_measurement
[2018-07-20 04:54:34,752] log.py->message():133 -- MESSAGE -- Imported plugin 0_modeling_a_measurement
[2018-07-20 04:54:34,755] log.py->message():133 -- MESSAGE -- Loading plugin 0_modeling_a_measurement
[2018-07-20 04:54:34,757] log.py->debug():112 -- DEBUG -- Loading modifiers from data/modifiers/measurement_modifiers.json
[2018-07-20 04:54:34,775] log.py->message():133 -- MESSAGE -- Loaded 20 modifiers from file data/modifiers/measurement_modifiers.json
[2018-07-20 04:54:34,779] log.py->message():133 -- MESSAGE -- Loaded 20 modifier descriptions from file data/modifiers/measurement_modifiers_desc.json
[2018-07-20 04:54:34,836] log.py->message():133 -- MESSAGE -- Loaded plugin 0_modeling_a_measurement
[2018-07-20 04:54:34,851] log.py->message():133 -- MESSAGE -- Importing plugin 0_modeling_background
[2018-07-20 04:54:34,883] log.py->message():133 -- MESSAGE -- Imported plugin 0_modeling_background
[2018-07-20 04:54:34,885] log.py->message():133 -- MESSAGE -- Loading plugin 0_modeling_background
[2018-07-20 04:54:34,944] log.py->message():133 -- MESSAGE -- Loaded plugin 0_modeling_background
[2018-07-20 04:54:34,951] log.py->message():133 -- MESSAGE -- Importing plugin 1_mhapi
[2018-07-20 04:54:35,009] log.py->message():133 -- MESSAGE -- Imported plugin 1_mhapi
[2018-07-20 04:54:35,012] log.py->message():133 -- MESSAGE -- Loading plugin 1_mhapi
[2018-07-20 04:54:35,724] log.py->message():133 -- MESSAGE -- Loaded plugin 1_mhapi
[2018-07-20 04:54:35,728] log.py->message():133 -- MESSAGE -- Importing plugin 2_foot_posing
[2018-07-20 04:54:35,753] log.py->message():133 -- MESSAGE -- Imported plugin 2_foot_posing
[2018-07-20 04:54:35,755] log.py->message():133 -- MESSAGE -- Loading plugin 2_foot_posing
[2018-07-20 04:54:35,757] log.py->message():133 -- MESSAGE -- Loaded plugin 2_foot_posing
[2018-07-20 04:54:35,760] log.py->message():133 -- MESSAGE -- Importing plugin 2_posing_expression
[2018-07-20 04:54:35,776] log.py->message():133 -- MESSAGE -- Imported plugin 2_posing_expression
[2018-07-20 04:54:35,779] log.py->message():133 -- MESSAGE -- Loading plugin 2_posing_expression
[2018-07-20 04:54:35,785] log.py->message():133 -- MESSAGE -- Loaded plugin 2_posing_expression
[2018-07-20 04:54:35,789] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_clothes_chooser
[2018-07-20 04:54:35,810] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_clothes_chooser
[2018-07-20 04:54:35,814] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_clothes_chooser
[2018-07-20 04:54:35,822] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_clothes_chooser
[2018-07-20 04:54:35,828] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_eye_chooser
[2018-07-20 04:54:35,844] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_eye_chooser
[2018-07-20 04:54:35,846] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_eye_chooser
[2018-07-20 04:54:35,854] log.py->message():133 -- MESSAGE -- Selecting proxy file "data/eyes/high-poly/high-poly.mhclo" from eyes library.
[2018-07-20 04:54:35,867] log.py->debug():112 -- DEBUG -- Loading binary proxy data/eyes/high-poly/high-poly.mhpxy.
[2018-07-20 04:54:35,873] log.py->debug():112 -- DEBUG -- Loading proxy file: data/eyes/high-poly/high-poly.mhpxy.
[2018-07-20 04:54:35,918] log.py->debug():112 -- DEBUG -- Loading material from file /usr/share/makehuman/data/eyes/materials/brown.mhmat
[2018-07-20 04:54:35,949] log.py->debug():112 -- DEBUG -- VectorUniform(AdditiveShading) = [ 0.]
[2018-07-20 04:54:35,951] log.py->debug():112 -- DEBUG -- Shader: adding built-in uniform gl_ModelViewProjectionMatrixTranspose
[2018-07-20 04:54:35,951] log.py->debug():112 -- DEBUG -- Shader: adding built-in uniform gl_NormalMatrix
[2018-07-20 04:54:35,951] log.py->debug():112 -- DEBUG -- VectorUniform(AdditiveShading) = [ 0.]
[2018-07-20 04:54:35,953] log.py->debug():112 -- DEBUG -- Loading binary mesh /usr/share/makehuman/data/eyes/high-poly/high-poly.npz.
[2018-07-20 04:54:36,156] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_eye_chooser
[2018-07-20 04:54:36,161] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_eyebrows
[2018-07-20 04:54:36,175] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_eyebrows
[2018-07-20 04:54:36,177] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_eyebrows
[2018-07-20 04:54:36,186] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_eyebrows
[2018-07-20 04:54:36,191] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_eyelashes
[2018-07-20 04:54:36,204] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_eyelashes
[2018-07-20 04:54:36,207] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_eyelashes
[2018-07-20 04:54:36,216] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_eyelashes
[2018-07-20 04:54:36,221] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_material_chooser
[2018-07-20 04:54:36,238] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_material_chooser
[2018-07-20 04:54:36,241] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_material_chooser
[2018-07-20 04:54:36,252] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_material_chooser
[2018-07-20 04:54:36,257] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_polygon_hair_chooser
[2018-07-20 04:54:36,259] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_polygon_hair_chooser
[2018-07-20 04:54:36,261] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_polygon_hair_chooser
[2018-07-20 04:54:36,267] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_polygon_hair_chooser
[2018-07-20 04:54:36,271] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_pose
[2018-07-20 04:54:36,273] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_pose
[2018-07-20 04:54:36,275] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_pose
[2018-07-20 04:54:36,282] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_pose
[2018-07-20 04:54:36,286] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_proxy_chooser
[2018-07-20 04:54:36,288] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_proxy_chooser
[2018-07-20 04:54:36,290] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_proxy_chooser
[2018-07-20 04:54:36,296] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_proxy_chooser
[2018-07-20 04:54:36,301] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_skeleton
[2018-07-20 04:54:36,320] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_skeleton
[2018-07-20 04:54:36,323] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_skeleton
[2018-07-20 04:54:36,333] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_skeleton
[2018-07-20 04:54:36,338] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_teeth
[2018-07-20 04:54:36,344] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_teeth
[2018-07-20 04:54:36,346] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_teeth
[2018-07-20 04:54:36,353] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_teeth
[2018-07-20 04:54:36,357] log.py->message():133 -- MESSAGE -- Importing plugin 3_libraries_tongue
[2018-07-20 04:54:36,361] log.py->message():133 -- MESSAGE -- Imported plugin 3_libraries_tongue
[2018-07-20 04:54:36,363] log.py->message():133 -- MESSAGE -- Loading plugin 3_libraries_tongue
[2018-07-20 04:54:36,369] log.py->message():133 -- MESSAGE -- Loaded plugin 3_libraries_tongue
[2018-07-20 04:54:36,373] log.py->message():133 -- MESSAGE -- Importing plugin 4_rendering_9_viewer
[2018-07-20 04:54:36,376] log.py->message():133 -- MESSAGE -- Imported plugin 4_rendering_9_viewer
[2018-07-20 04:54:36,378] log.py->message():133 -- MESSAGE -- Loading plugin 4_rendering_9_viewer
[2018-07-20 04:54:36,384] log.py->message():133 -- MESSAGE -- Loaded plugin 4_rendering_9_viewer
[2018-07-20 04:54:36,388] log.py->message():133 -- MESSAGE -- Importing plugin 4_rendering_opengl
[2018-07-20 04:54:36,407] log.py->message():133 -- MESSAGE -- Imported plugin 4_rendering_opengl
[2018-07-20 04:54:36,409] log.py->message():133 -- MESSAGE -- Loading plugin 4_rendering_opengl
[2018-07-20 04:54:36,414] log.py->debug():112 -- DEBUG -- Assigning setting rendering_width value 800 that was loaded before the setting was declared.
[2018-07-20 04:54:36,414] log.py->debug():112 -- DEBUG -- Assigning setting rendering_height value 600 that was loaded before the setting was declared.
[2018-07-20 04:54:36,415] log.py->debug():112 -- DEBUG -- Assigning setting GL_RENDERER_SSS value False that was loaded before the setting was declared.
[2018-07-20 04:54:36,415] log.py->debug():112 -- DEBUG -- Assigning setting GL_RENDERER_AA value True that was loaded before the setting was declared.
[2018-07-20 04:54:36,420] extensions.py->hasGLExtension():148 -- DEBUG -- GL Extension GL_ARB_framebuffer_object available
[2018-07-20 04:54:36,420] extensions.py->finalise():182 -- DEBUG -- Chose alternate: glGenRenderbuffers from glGenRenderbuffers, glGenRenderbuffersEXT
[2018-07-20 04:54:36,421] extensions.py->finalise():182 -- DEBUG -- Chose alternate: glBindRenderbuffer from glBindRenderbuffer, glBindRenderbufferEXT
[2018-07-20 04:54:36,421] extensions.py->finalise():182 -- DEBUG -- Chose alternate: glRenderbufferStorage from glRenderbufferStorage, glRenderbufferStorageEXT
[2018-07-20 04:54:36,421] extensions.py->finalise():182 -- DEBUG -- Chose alternate: glGenFramebuffers from glGenFramebuffers, glGenFramebuffersEXT
[2018-07-20 04:54:36,422] extensions.py->finalise():182 -- DEBUG -- Chose alternate: glBindFramebuffer from glBindFramebuffer, glBindFramebufferEXT
[2018-07-20 04:54:36,422] extensions.py->finalise():182 -- DEBUG -- Chose alternate: glFramebufferRenderbuffer from glFramebufferRenderbuffer, glFramebufferRenderbufferEXT
[2018-07-20 04:54:36,423] log.py->message():133 -- MESSAGE -- Loaded plugin 4_rendering_opengl
[2018-07-20 04:54:36,428] log.py->message():133 -- MESSAGE -- Importing plugin 4_rendering_scene
[2018-07-20 04:54:36,431] log.py->message():133 -- MESSAGE -- Imported plugin 4_rendering_scene
[2018-07-20 04:54:36,433] log.py->message():133 -- MESSAGE -- Loading plugin 4_rendering_scene
[2018-07-20 04:54:36,439] mhmain.py->addSetting():326 -- NOTICE -- Setting rendering_width is already declared. Adding it again has no effect.
[2018-07-20 04:54:36,440] mhmain.py->addSetting():326 -- NOTICE -- Setting rendering_height is already declared. Adding it again has no effect.
[2018-07-20 04:54:36,445] log.py->message():133 -- MESSAGE -- Loaded plugin 4_rendering_scene
[2018-07-20 04:54:36,449] log.py->message():133 -- MESSAGE -- Importing plugin 5_settings_0_settings
[2018-07-20 04:54:36,452] log.py->message():133 -- MESSAGE -- Imported plugin 5_settings_0_settings
[2018-07-20 04:54:36,453] log.py->message():133 -- MESSAGE -- Loading plugin 5_settings_0_settings
[2018-07-20 04:54:36,540] log.py->debug():112 -- DEBUG -- Setting language to english
[2018-07-20 04:54:36,546] log.py->message():133 -- MESSAGE -- Theme makehuman version 1.1.0
[2018-07-20 04:54:36,551] log.py->debug():112 -- DEBUG -- Loaded theme data/themes/makehuman.mht
[2018-07-20 04:54:37,910] log.py->debug():112 -- DEBUG -- Loaded Qt style data/themes/makehuman.qss
[2018-07-20 04:54:37,994] log.py->message():133 -- MESSAGE -- Loaded plugin 5_settings_0_settings
[2018-07-20 04:54:38,024] log.py->message():133 -- MESSAGE -- Importing plugin 5_settings_mouse
[2018-07-20 04:54:38,030] log.py->message():133 -- MESSAGE -- Imported plugin 5_settings_mouse
[2018-07-20 04:54:38,031] log.py->message():133 -- MESSAGE -- Loading plugin 5_settings_mouse
[2018-07-20 04:54:38,044] log.py->message():133 -- MESSAGE -- Loaded plugin 5_settings_mouse
[2018-07-20 04:54:38,050] log.py->message():133 -- MESSAGE -- Importing plugin 5_settings_shortcuts
[2018-07-20 04:54:38,053] log.py->message():133 -- MESSAGE -- Imported plugin 5_settings_shortcuts
[2018-07-20 04:54:38,055] log.py->message():133 -- MESSAGE -- Loading plugin 5_settings_shortcuts
[2018-07-20 04:54:38,084] log.py->message():133 -- MESSAGE -- Loaded plugin 5_settings_shortcuts
[2018-07-20 04:54:38,092] log.py->message():133 -- MESSAGE -- Importing plugin 6_help
[2018-07-20 04:54:38,121] log.py->message():133 -- MESSAGE -- Imported plugin 6_help
[2018-07-20 04:54:38,123] log.py->message():133 -- MESSAGE -- Loading plugin 6_help
[2018-07-20 04:54:38,141] log.py->message():133 -- MESSAGE -- Loaded plugin 6_help
[2018-07-20 04:54:38,146] log.py->message():133 -- MESSAGE -- Importing plugin 7_data
[2018-07-20 04:54:38,150] log.py->message():133 -- MESSAGE -- Imported plugin 7_data
[2018-07-20 04:54:38,153] log.py->message():133 -- MESSAGE -- Loading plugin 7_data
[2018-07-20 04:54:38,397] log.py->message():133 -- MESSAGE -- Loaded plugin 7_data
[2018-07-20 04:54:38,403] log.py->message():133 -- MESSAGE -- Importing plugin 7_example
[2018-07-20 04:54:38,413] log.py->message():133 -- MESSAGE -- Imported plugin 7_example
[2018-07-20 04:54:38,415] log.py->message():133 -- MESSAGE -- Loading plugin 7_example
[2018-07-20 04:54:38,435] log.py->message():133 -- MESSAGE -- Loaded plugin 7_example
[2018-07-20 04:54:38,441] log.py->message():133 -- MESSAGE -- Importing plugin 7_expression_mixer
[2018-07-20 04:54:38,459] log.py->message():133 -- MESSAGE -- Imported plugin 7_expression_mixer
[2018-07-20 04:54:38,461] log.py->message():133 -- MESSAGE -- Loading plugin 7_expression_mixer
[2018-07-20 04:54:38,481] log.py->message():133 -- MESSAGE -- Loaded plugin 7_expression_mixer
[2018-07-20 04:54:38,487] log.py->message():133 -- MESSAGE -- Importing plugin 7_logging
[2018-07-20 04:54:38,489] log.py->message():133 -- MESSAGE -- Imported plugin 7_logging
[2018-07-20 04:54:38,491] log.py->message():133 -- MESSAGE -- Loading plugin 7_logging
[2018-07-20 04:54:38,599] log.py->message():133 -- MESSAGE -- Loaded plugin 7_logging
[2018-07-20 04:54:38,604] log.py->message():133 -- MESSAGE -- Importing plugin 7_material_editor
[2018-07-20 04:54:38,626] log.py->message():133 -- MESSAGE -- Imported plugin 7_material_editor
[2018-07-20 04:54:38,628] log.py->message():133 -- MESSAGE -- Loading plugin 7_material_editor
[2018-07-20 04:54:38,649] log.py->message():133 -- MESSAGE -- Loaded plugin 7_material_editor
[2018-07-20 04:54:38,656] log.py->message():133 -- MESSAGE -- Importing plugin 7_profile
[2018-07-20 04:54:38,670] log.py->message():133 -- MESSAGE -- Imported plugin 7_profile
[2018-07-20 04:54:38,672] log.py->message():133 -- MESSAGE -- Loading plugin 7_profile
[2018-07-20 04:54:38,693] log.py->message():133 -- MESSAGE -- Loaded plugin 7_profile
[2018-07-20 04:54:38,701] log.py->message():133 -- MESSAGE -- Importing plugin 7_scene_editor
[2018-07-20 04:54:38,716] log.py->message():133 -- MESSAGE -- Imported plugin 7_scene_editor
[2018-07-20 04:54:38,717] log.py->message():133 -- MESSAGE -- Loading plugin 7_scene_editor
[2018-07-20 04:54:38,724] mhmain.py->addSetting():326 -- NOTICE -- Setting rendering_width is already declared. Adding it again has no effect.
[2018-07-20 04:54:38,727] mhmain.py->addSetting():326 -- NOTICE -- Setting rendering_height is already declared. Adding it again has no effect.
[2018-07-20 04:54:38,730] log.py->debug():112 -- DEBUG -- Assigning setting Scene_Editor_FileDlgPath value /home/obi-ron/makehuman/v1/data/scenes that was loaded before the setting was declared.
[2018-07-20 04:54:38,740] log.py->message():133 -- MESSAGE -- Loaded plugin 7_scene_editor
[2018-07-20 04:54:38,746] log.py->message():133 -- MESSAGE -- Importing plugin 7_scripting
[2018-07-20 04:54:38,755] log.py->message():133 -- MESSAGE -- Imported plugin 7_scripting
[2018-07-20 04:54:38,757] log.py->message():133 -- MESSAGE -- Loading plugin 7_scripting
[2018-07-20 04:54:38,779] log.py->message():133 -- MESSAGE -- Loaded plugin 7_scripting
[2018-07-20 04:54:38,787] log.py->message():133 -- MESSAGE -- Importing plugin 7_shell
[2018-07-20 04:54:38,790] log.py->message():133 -- MESSAGE -- Imported plugin 7_shell
[2018-07-20 04:54:38,792] log.py->message():133 -- MESSAGE -- Loading plugin 7_shell
[2018-07-20 04:54:38,798] log.py->message():133 -- MESSAGE -- Loaded plugin 7_shell
[2018-07-20 04:54:38,804] log.py->message():133 -- MESSAGE -- Importing plugin 7_targets
[2018-07-20 04:54:38,807] log.py->message():133 -- MESSAGE -- Imported plugin 7_targets
[2018-07-20 04:54:38,809] log.py->message():133 -- MESSAGE -- Loading plugin 7_targets
[2018-07-20 04:54:38,818] log.py->message():133 -- MESSAGE -- Loaded plugin 7_targets
[2018-07-20 04:54:38,824] log.py->message():133 -- MESSAGE -- Importing plugin 8_asset_downloader
[2018-07-20 04:54:38,866] log.py->message():133 -- MESSAGE -- Imported plugin 8_asset_downloader
[2018-07-20 04:54:38,869] log.py->message():133 -- MESSAGE -- Loading plugin 8_asset_downloader
[2018-07-20 04:54:39,094] log.py->warning():119 -- WARNING -- Could not load 8_asset_downloader
    module.load(self)
[2018-07-20 04:54:39,126] log.py->message():133 -- MESSAGE -- Importing plugin 8_server_socket
[2018-07-20 04:54:39,149] log.py->message():133 -- MESSAGE -- Imported plugin 8_server_socket
[2018-07-20 04:54:39,151] log.py->message():133 -- MESSAGE -- Loading plugin 8_server_socket
[2018-07-20 04:54:39,162] log.py->message():133 -- MESSAGE -- Loaded plugin 8_server_socket
[2018-07-20 04:54:39,167] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_bvh
[2018-07-20 04:54:39,197] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_bvh
[2018-07-20 04:54:39,200] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_bvh
[2018-07-20 04:54:39,210] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_bvh
[2018-07-20 04:54:39,213] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_collada
[2018-07-20 04:54:39,218] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_collada
[2018-07-20 04:54:39,221] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_collada
[2018-07-20 04:54:39,232] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_collada
[2018-07-20 04:54:39,236] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_fbx
[2018-07-20 04:54:39,238] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_fbx
[2018-07-20 04:54:39,240] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_fbx
[2018-07-20 04:54:39,245] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_fbx
[2018-07-20 04:54:39,248] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_light
[2018-07-20 04:54:39,259] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_light
[2018-07-20 04:54:39,261] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_light
[2018-07-20 04:54:39,265] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_light
[2018-07-20 04:54:39,270] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_mhx2
[2018-07-20 04:54:39,298] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_mhx2
[2018-07-20 04:54:39,301] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_mhx2
[2018-07-20 04:54:39,308] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_mhx2
[2018-07-20 04:54:39,312] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_obj
[2018-07-20 04:54:39,331] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_obj
[2018-07-20 04:54:39,334] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_obj
[2018-07-20 04:54:39,341] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_obj
[2018-07-20 04:54:39,345] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_ogre
[2018-07-20 04:54:39,348] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_ogre
[2018-07-20 04:54:39,351] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_ogre
[2018-07-20 04:54:39,356] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_ogre
[2018-07-20 04:54:39,359] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_stl
[2018-07-20 04:54:39,362] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_stl
[2018-07-20 04:54:39,364] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_stl
[2018-07-20 04:54:39,370] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_stl
[2018-07-20 04:54:39,374] log.py->message():133 -- MESSAGE -- Importing plugin 9_export_uvmap
[2018-07-20 04:54:39,376] log.py->message():133 -- MESSAGE -- Imported plugin 9_export_uvmap
[2018-07-20 04:54:39,379] log.py->message():133 -- MESSAGE -- Loading plugin 9_export_uvmap
[2018-07-20 04:54:39,382] log.py->message():133 -- MESSAGE -- Loaded plugin 9_export_uvmap
[2018-07-20 04:54:39,385] log.py->message():133 -- MESSAGE -- Loading GUI
[2018-07-20 04:54:39,457] log.py->debug():112 -- DEBUG -- showing category Modelling
[2018-07-20 04:54:39,457] log.py->debug():112 -- DEBUG -- showing task Macro modelling
[2018-07-20 04:54:39,511] log.py->message():133 -- MESSAGE -- Loading theme
[2018-07-20 04:54:39,514] log.py->message():133 -- MESSAGE -- Theme makehuman version 1.1.0
[2018-07-20 04:54:39,521] log.py->debug():112 -- DEBUG -- Loaded theme data/themes/makehuman.mht
[2018-07-20 04:54:41,227] log.py->debug():112 -- DEBUG -- Loaded Qt style data/themes/makehuman.qss
[2018-07-20 04:54:41,269] log.py->message():133 -- MESSAGE -- Applying targets
[2018-07-20 04:54:41,662] log.py->debug():112 -- DEBUG -- Updating skeleton joint positions
[2018-07-20 04:54:41,742] log.py->debug():112 -- DEBUG -- Done baking animations
[2018-07-20 04:54:41,856] log.py->message():133 -- MESSAGE -- Loading macro targets
[2018-07-20 04:54:44,898] log.py->message():133 -- MESSAGE -- Loading done
[2018-07-20 04:54:44,901] log.py->message():133 -- MESSAGE --
[2018-07-20 04:54:45,358] log.py->debug():112 -- DEBUG -- Creating new texture for dynamic image data/litspheres/adaptive_skin_tone.png.
[2018-07-20 04:54:45,361] log.py->debug():112 -- DEBUG -- initTexture: 256, 256, False
[2018-07-20 04:54:45,374] log.py->debug():112 -- DEBUG -- Creating new texture for image /usr/share/makehuman/data/eyes/materials/brown_eye.png.
[2018-07-20 04:54:45,457] log.py->debug():112 -- DEBUG -- initTexture: 1024, 1024, False
[2018-07-20 04:54:45,457] log.py->debug():112 -- DEBUG -- Creating new texture for image /usr/share/makehuman/data/litspheres/skinmat_eye.png.
[2018-07-20 04:54:45,462] log.py->debug():112 -- DEBUG -- initTexture: 256, 256, False
[2018-07-20 04:54:48,591] log.py->debug():112 -- DEBUG -- hiding category Modelling
[2018-07-20 04:54:48,592] log.py->debug():112 -- DEBUG -- showing category Utilities
[2018-07-20 04:54:48,593] log.py->debug():112 -- DEBUG -- hiding task Macro modelling
[2018-07-20 04:54:48,593] log.py->debug():112 -- DEBUG -- showing task Data
[2018-07-20 04:54:49,711] log.py->debug():112 -- DEBUG -- hiding task Data
[2018-07-20 04:54:49,712] log.py->debug():112 -- DEBUG -- showing task Logs
[2018-07-20 04:58:13,630] log.py->debug():112 -- DEBUG -- hiding task Logs
[2018-07-20 04:58:13,632] log.py->debug():112 -- DEBUG -- showing task Material Editor
[2018-07-20 04:58:14,556] log.py->debug():112 -- DEBUG -- hiding task Material Editor
[2018-07-20 04:58:14,557] log.py->debug():112 -- DEBUG -- showing task Logs
OBI_Ron
Postby Aranuvir » Fri Jul 20, 2018 10:06 am
The log don't show further problems. Currently I don't have an idea. Perhaps Joel can help.
Just to make sure, perhaps re-dowload assetdownlad^ and mhapi^. Delete the old plugins and their pyc files. And when you reinstall the plugins, make sure ALL files have the correct permissions. Furthermore make sure pyside or python(2)-pyside is not installed.
Postby joepal » Fri Jul 20, 2018 3:46 pm
This indeed looks like a pyside/pyqt4 conflict. To be clear: You should not have pyqt4 and pyside installed at the same time.
Can you provide the output of:
dpkg -l | grep -i python | grep -i qt
Also, just to be sure: Are you downloading all modules from their respective repositories? There is, confusingly enough, an old repository which contains several modules. This is deprecated. MHAPI and the asset downloader should be downloaded separately from:
https://github.com/makehumancommunity/c ... gins-mhapi
https://github.com/makehumancommunity/c ... etdownload
Postby OBI_Ron » Fri Jul 20, 2018 8:55 pm
joepal,
Brilliant!! - I must have gotten the plugins from an old - out of date link- downloading those fro github fixed it.
I also uninstalled the pyside stuff.
Fires up MH - no errors
I really appreciate the help!!!
OBI_Ron
Postby klaudio001 » Wed Aug 26, 2020 4:20 pm
Aranuvir wrote:I might be wrong, but it reminds me of some PyQt4 Pyside mismatch, I’ve seen some time ago, when we did some tests with alternatives for PyQt4. Can you check your package management system, if you have Pyside installed?
HI there, I am having the same error on my MAC.
I am currently using MH 1.1.1 what should exactly do, in order to have this issue addressed??
Thanks in advance
File "plugins/8_asset_downloader/assetdownload.py", line 69, in __init__
File "plugins/1_mhapi/_utility.py", line 119, in getLogChannel
File "plugins/1_mhapi/logchannel.py", line 43, in __init__
TypeError: 'encoding' is an invalid keyword argument for this function
klaudio001
