You're really fast. Thanks again.
joepal wrote:And this is a computer that MH worked on previously? As in did you repair the computer, or did you get a completely new one?
It's exactly the same computer. It refused to boot, but instead corrupted the parttion table and file systems. I replaced the battery of the main board, reinstalled the OS and restored my home directory from a backup. MH always worked fine before I installed ubuntu 15.10.
Intel is known to have a somewhat erratic support for later versions of OpenGL.
Also on linux? I know about the trouble with MH on windows in conjunction with Intel GPUs.
Can you try to start MH with "--noshaders"?
This looks okay, so I definitely have an OpenGL problem. I will use my spare partition to install ubuntu 15.04. If MH works there, it's an issue with the distro and it's drivers. If not, there's something else wrong.
