Hair is rendered but not the rest (body, ...)
Postby Nadow » Wed Jan 13, 2010 7:43 am
Ok I have the problem that the hair is rendered well in Aqsis but the rest including the body is not rendered.
The lightmap is renderred well.
I use the Subversion Revision r623.
Here is the log message from the terminal:
01/13/2010 08:34:01 ERROR: RiSubdivisionMesh contains non-manifold data
Nadow
Desaster Games
// Lead artist
Nadow
Re: Hair is rendered but not the rest (body, ...)
Postby pgregory » Wed Jan 13, 2010 3:48 pm
This is a known problem. The mesh that MH generates seems to have some non-manifold information, however, in a more recent version of Aqsis we have modified the code to fixup the mesh at runtime, rather than cause an error. The best solution would be to get a newer version of Aqsis, 1.6.0 is the latest.
Paul
pgregory
Postby Manuel » Wed Jan 13, 2010 9:15 pm
Paul[*], thanks for reply!
The mesh used in MH has some "non-manifold" because there are different open pieces (see image attached), but I've never notice of problems because this, even with early Aqsis.
@Nadow: can you post more from the rendering log? And maybe an image of results?
Best,
[*]Paul Gregory is the admin of Aqsis Project
Postby VitalBodies » Wed Jan 13, 2010 11:08 pm
I had the same issue where the hair would render but not the body.
If you are using Ubuntu check out the post i wrote to help.
http://www.vitalbodies.com/blog/2010/01/09/getting-makehuman-to-run-in-ubuntu/
Ultimately upgrading to Aqsis 1.6 and recompiling the shaders is what resolved the issue.
Ubuntu 10.04 (Lucid) 64-bit
http://www.vitalbodies.net/site/art-des ... anorg.html
MakeHuman 1.0Alpha4 - Blender - Inkscape - Gimp - AQSIS 1.6
VitalBodies
Postby cousteau » Mon Jan 25, 2010 5:14 pm
There's an aqsis ppa repository: https://launchpad.net/~aqsisteam/+archive/ppa - read instructions there
(uninstall aqsis before installing the 1.6 version)
cousteau
