by VitalBodies » Mon Jan 11, 2010 7:37 am
Getting closer:
COMMAND aqsis -Progress renderman_output/scena.rib
01/10/2010 23:31:18 ERROR: could not load shader "onlyci": Shader compiled with an old/different version (1.2.0) of aqsis. Please recompile.
01/10/2010 23:31:18 ERROR: could not load shader "lightmap": Shader compiled with an old/different version (1.2.0) of aqsis. Please recompile.
And:
01/10/2010 23:31:22 ERROR: could not load shader "skin": Shader compiled with an old/different version (1.2.0) of aqsis. Please recompile.
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14073
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14074
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14075
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14076
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14181
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14182
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14183
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14184
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14199
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14200
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14201
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14202
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14223
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14224
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14225
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14226
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14229
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14230
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14231
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14232
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14235
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14236
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14237
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14238
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14241
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14242
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14243
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14244
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14435
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14436
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14437
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14465
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14466
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14467
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14469
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14471
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14472
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14473
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14475
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14477
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14478
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14481
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14483
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14484
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14485
01/10/2010 23:31:22 ERROR: Found a non-manifold vertex in the control hull of object "unnamed" at vertex 14487
01/10/2010 23:31:22 ERROR: could not load shader "hair": Shader compiled with an old/different version (1.2.0) of aqsis. Please recompile.
Anyone know how to recompile?
I removed (I thought) AQSIS 1.2 (and lib) before installing 1.6.
aqsl -version
aqsl version 1.6.0 (revision 0)
compiled Oct 20 2009 19:29:12
UPDATE: I will try doing the updates (update manager) and see if that helps... NOPE did not help.
VitalBodies on Mon Jan 11, 2010 7:41 am, edited 1 time in total.
