Nightly Builds on Ubuntu 9.04
Postby brkurt » Thu Dec 17, 2009 9:31 pm
Hello everyone...
What can I do to overcome this problem in Ubuntu 9.04 32 Desktop?
#./makehuman
Original exception was:
File "<string>", line 1, in <module>
File "main.py", line 57, in <module>
import subprocess
File "/usr/lib/python2.6/subprocess.py", line 401, in <module>
import select
ImportError: No module named select
Could not run main Python script
and yes, I have run "sudo apt-get install libsdl1.2debian libsdl-image1.2"
Re: Nightly Builds on Ubuntu 9.04
Postby joepal » Fri Dec 18, 2009 1:28 pm
No great ideas from my side, never saw the error before.
Looks like a python error to me, and I'm kind of noob regarding python. If I had the problem I'd try pulling in some more python packages, like trying "apt-get install python2.6 python2.6-dev". Not because of knowing what I was doing but because it probably wouldn't hurt. :)
Postby joepal » Fri Dec 18, 2009 1:31 pm
Oh, wait... Now I see.
The i386 package is linked against python 2.5. This might cause some problems.
I think both python versions can co-exist on the system, so try running "apt-get install python2.5 python2.5-dev".
Postby brkurt » Fri Dec 18, 2009 2:39 pm
Many, many thanks. This will probably also fix the 9.10 32-bit problem.
Here's a screenshot to prove it works: http://www.geekopolis.ca/makehuman/MakeHuman_Screenshot_20091218.png
This info should definitely go on the Nightly Builds resources page.
FYI: The Nightly Builds work on the OpenArtist distro, but the compile-MHPhoenix-from-source-svn on that distro no longer works.
