Page 2 of 2
Re: Render
PostPosted: Thu Feb 21, 2008 10:17 pm
by cgTobi
How did you install Aqsis 0.9.1? Eventually this provides some information about how it can be removed.
Tobi
Re: Render
PostPosted: Fri Feb 22, 2008 11:05 am
by Lars
I tried Pacifist and could open the package. I put the contents in the Graphics folder (which name?), but makehuman now tells me there is no renderer. Restarted, re-installed makehuman.. no difference. Ideas?
@cgTobi
I used the provided way and then moved everything in the graphics folder as described here: http://makewiki.aleppax.it/pmwiki/pmwik ... ntegration
Pixie is also not recognized.
I really look forward to be able to work with makehuman! Hope there you dicover a way for me to be able to do this.
Thanks
Lars
Re: Render
PostPosted: Sat Feb 23, 2008 6:14 pm
by cgTobi
It looks like you have to modify your makehuman.parameters which resides in Documents/makehuman/
The XML file has some parameters like:
<MAKEHUMAN>
<rendering_parameters>
<aqsis_path command="aqs">
/Applications/Graphics/MacAqsis.0.9.1/
</aqsis_path>
try to change that to the new folder. If you still have problems rendering with Aqsis you can also visit our helpdesk :) IRC channel #aqsis on freenode.net
cgTobi
Re: Render
PostPosted: Sat Feb 23, 2008 8:15 pm
by Lars
Sounds good. Did it exactly the way described. Same result. Using the console "aqs" tells me everything is the same. Changing the location results in a message that I changed tthe location.. but afterwards it appears the changes are lost. Strange. I also renamed my folder to the one tatooed to makehuman... same result. Restarted, rebooted... same. :-/
Ideas?
