Unreal: Root bone orientation
Postby fortuna » Sat Jul 10, 2021 4:29 pm
I detected that the root bone of an imported fbx has some rotation. See image:
https://ibb.co/hZbdzSc
I retargeted animations to another Skeleton. The ue4 manequinn has no rotation on the root bone.
Although animation retargeting works, i have some issues in the retargeted anim blueprints and bone calculations probably the cause (just guessing) of failing of some advanced animations (carrying weapons and items, and more). Is it possible to fix (remove) the root bone rotation?
https://ibb.co/wCCHmf2
fortuna
Re: Unreal: Root bone orientation
Postby fortuna » Sun Jul 11, 2021 10:47 am
At least i found a way to remove the extra bone. The node above the root bone must be named **Armature** and not not main_root as described in the wiki:
http://www.makehumancommunity.org/wiki/ ... them_there
But the root bone has still rotation.
fortuna
Postby darolin » Wed Dec 20, 2023 12:37 am
For Climatempo, weather is more than just numbers on a display, it's accurate data that allows you to create a safe environment in your daily life and be ready for anything. Plan your days relying on Climatempo's detailed forecasts and keep your activities safe in any climate. At https://climatempo.com/ you can view a map by region to learn more about tomorrow.
darolin
Return to Game development
Users browsing this forum: warev and 1 guest
