MPFB2 error when enabling the add-on in Blender
Postby Grrvvpp23 » Fri May 19, 2023 10:35 am
Hello!
I hope I'm posting at the right place, as I've been trying to find a solution to this error but I couldn't find it. If not please let me know where could I share this!
I am trying to enable the add-on in Blender, but after installing the package correctly (made sure it was the latest release), I get a Python error when I click the tick to enable the add-on.
I didn't do anything special, I first added the MakeHuman add-ons in Blender without a problem and all working fine, then I found out about MPFB2, installed it and when enabling it I got this error:
[INFO ] mpfb.init ..............................: Build info 20230518
[INFO ] services.locationservice ...............: mh_user_dir is not explicitly set but autodiscovery is disabled
[INFO ] services.uiservice .....................: Rebuilding the list of available importer presets (for presets panel)
[INFO ] services.uiservice .....................: Rebuilding the list of available importer presets (for importer panel)Exception in module register(): C:\Users\User1\AppData\Roaming\Blender Foundation\Blender\3.4\scripts\addons\mpfb\__init__.py
File "C:\Program Files\Blender Foundation\Blender 3.4\3.4\scripts\modules\addon_utils.py", line 369, in enable
mod.register()
File "C:\Users\User1\AppData\Roaming\Blender Foundation\Blender\3.4\scripts\addons\mpfb\__init__.py", line 113, in register
import mpfb.ui
File "C:\Users\User1\AppData\Roaming\Blender Foundation\Blender\3.4\scripts\addons\mpfb\ui\__init__.py", line 17, in <module>
from mpfb.ui.newhuman import *
File "C:\Users\User1\AppData\Roaming\Blender Foundation\Blender\3.4\scripts\addons\mpfb\ui\newhuman\__init__.py", line 11, in <module>
from .frompresetspanel import MPFB_PT_From_Presets_Panel
File "C:\Users\User1\AppData\Roaming\Blender Foundation\Blender\3.4\scripts\addons\mpfb\ui\newhuman\frompresetspanel.py", line 15, in <module>
PRESETS_HUMAN_PROPERTIES = SceneConfigSet.from_definitions_in_json_directory(PRESETS_HUMAN_PROPERTIES_DIR, prefix="FPR_")
File "C:\Users\User1\AppData\Roaming\Blender Foundation\Blender\3.4\scripts\addons\mpfb\services\sceneconfigset.py", line 23, in from_definitions_in_json_directory
known_properties = BlenderConfigSet.get_definitions_in_json_directory(properties_dir)
File "C:\Users\User1\AppData\Roaming\Blender Foundation\Blender\3.4\scripts\addons\mpfb\services\blenderconfigset.py", line 40, in get_definitions_in_json_directory
data = json.load(json_file)
File "C:\Program Files\Blender Foundation\Blender 3.4\3.4\python\lib\json\__init__.py", line 293, in load
return loads(fp.read(),
File "C:\Program Files\Blender Foundation\Blender 3.4\3.4\python\lib\json\__init__.py", line 346, in loads
return _default_decoder.decode(s)
File "C:\Program Files\Blender Foundation\Blender 3.4\3.4\python\lib\json\decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "C:\Program Files\Blender Foundation\Blender 3.4\3.4\python\lib\json\decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 12 column 5 (char 685)
I even tried to delete other MakeHuman packages but that didn't change the outcome. Can somebody help me with this problem?
Thanks in advance!
Grrvvpp23
Re: MPFB2 error when enabling the add-on in Blender
Postby delwynedna » Tue Oct 10, 2023 4:42 am
The error message suggests that there is an issue with parsing a JSON file. This could be related to a corrupted or incorrectly formatted JSON fileSnow Rider 3D.
delwynedna
Return to Blender and MPFB
