Apply targets/shape keys to proxies.
Postby ashdom » Mon Jan 09, 2023 4:25 pm
Hello,
in this tutorial, I notice that when creating the rig, the "model" menu disappears, which is coherent because the rig could certainly act in an unexpected way with a too distorted mesh.
However, some target sliders could, for some, modify the proxy mesh. Also, some sliders which has low impact on the mesh could still be useful afterwards.
Could we force some target sliders to stay on even after the framework is created and topology assets are added?
edit: changed the title to something more correct 2023-01-13
ashdom
Re: keep on some model sliders after rigging
Postby ashdom » Tue Jan 10, 2023 1:02 am
I was wrong, it's not after rigging that the «model» menu disappears (you simply need to select again the mesh, as the armature is selected instead, to reactivate it) but after applying a topology asset.
ashdom
Re: Apply targets/shape keys to proxies.
Postby ashdom » Fri Jan 13, 2023 10:54 pm
This issue seems related somehow
https://github.com/makehumancommunity/mpfb2/issues/76
This issue helped me understand how to apply targets to proxy meshes :D
ashdom
Postby villagetunic » Tue Apr 23, 2024 3:33 am
ashdom wrote:Hello,
You're completely correct regarding the difficulties of keeping sliders active after generating the rig, particularly when dealing with heavily distorted meshes. Here are some strategies to consider:
In rigging workflows, the "model" menu frequently disappears. This occurs because the rig no longer directly manipulates the source mesh. Instead, the rig directs a new, optimized mesh (also known as a bind pose or bind mesh) created expressly for animation.
villagetunic
Return to Blender and MPFB
