python code for camera.
Postby b1bb2 » Fri Sep 24, 2021 12:52 am
I am learning bpy. Here is code I put together that takes picture of object at origon, from cameras on axis. Some cameras are missing. More light needs to be added. The code works, but I do not understand some of it. Your comments are appreciated. How can a specific camera be selected?
# camera.bpy  b1bb2  2021 09 23
# blender/2.93.1/extract/blender-2.93.1-linux-x64/blender -P blender/2.93.1/bpy/camera.bpy
# in GUI:
# x axis is red
# y axis is green
# z axis is not shown
# positive x is at bottom of screen, near right side of screen.
# negative x is at top of screen, near left side of screen.
# origon is near center of screen
# -pi/2 radians = -90 degrees
# pi/4 radians = 45 degrees
# positive z is at top of screen
# negative z is at bottom of screen
import bpy
from math import pi
# take a picture of start, before we change it.
bpy.context.scene.render.filepath='blender/2.93.1/png/camera/start.png'
bpy.ops.render.render(write_still=True)
bpy.ops.object.select_by_type(type='CAMERA')
bpy.ops.object.delete()
# more light is needed.
# here are some ways to point camera toward origon:
# locate camera on positive x axis. rotate camera pi/2 radians about y axis.
bpy.ops.object.camera_add(location=(+10.0, 0.0, 0.0), rotation=(0.0, +pi/2, 0.0))
camerapxabouty=bpy.context.active_object
bpy.context.scene.camera=camerapxabouty
bpy.ops.object.select_camera()
bpy.context.scene.render.filepath='blender/2.93.1/png/camera/camerapxabouty.png'
# locate camera on negative x axis. rotate camera -pi/2 radians about y axis.
bpy.ops.object.camera_add(location=(-10.0, 0.0, 0.0), rotation=(0.0, -pi/2, 0.0))
cameranxabouty=bpy.context.active_object
bpy.context.scene.camera=cameranxabouty
bpy.context.scene.render.filepath='blender/2.93.1/png/camera/cameranxabouty.png'
# locate camera on negative x axis. rotate camera pi/4 radians about x axis.
bpy.ops.object.camera_add(location=(-10.0, 0.0, 0.0), rotation=(+pi/4, 0.0, 0.0))
cameranxaboutx=bpy.context.active_object
bpy.context.scene.camera=cameranxaboutx
bpy.context.scene.render.filepath='blender/2.93.1/png/camera/cameranxaboutx.png'
# locate camera on positive z axis. rotate camera 0 radians about all axis.
bpy.ops.object.camera_add(location=(0.0, 0.0, +10.0), rotation=(0.0, 0.0, 0.0))
camerapz=bpy.context.active_object
bpy.context.scene.camera=camerapz
bpy.context.scene.render.filepath='blender/2.93.1/png/camera/camerapz.png'
# locate camera on negative z axis. rotate camera pi radians about x axis.
bpy.ops.object.camera_add(location=(0.0, 0.0, -10.0), rotation=(+pi, 0.0, 0.0))
cameranzaboutx=bpy.context.active_object
bpy.context.scene.camera=cameranzaboutx
bpy.context.scene.render.filepath='blender/2.93.1/png/camera/cameranzaboutx.png'
# locate camera on negative z axis. rotate camera pi radians about y axis.
bpy.ops.object.camera_add(location=(0.0, 0.0, -10.0), rotation=(0.0, +pi, 0.0))
cameranzabouty=bpy.context.active_object
bpy.context.scene.camera=cameranzabouty
bpy.context.scene.render.filepath='blender/2.93.1/png/camera/cameranzabouty.png'
print("end camera.bpy")
b1bb2
Re: python code for camera.
Postby joepal » Fri Sep 24, 2021 10:09 am
If you know the name of the camera, you can use that to find the relevant object:
camera_obj = bpy.context.scene.objects["my_primary_camera"]
camera_obj.select_set(True)
bpy.context.scene.objects.active = camera_obj
Postby b1bb2 » Fri Sep 24, 2021 9:26 pm
Is this what you said to do? It will not work.
import bpy
from math import pi
camera_obj = bpy.context.scene.objects["cameranxabouty"]
# cameranxabouty=bpy.context.active_object
# bpy.context.scene.camera=cameranxabouty
# bpy.ops.object.select_camera()
bpy.context.scene.render.filepath='/home/bullseye/blender/2.93.1/png/test/cameranxabouty.png'
print("end test.bpy")
KeyError: 'bpy_prop_collection[key]: key "cameranxabouty" not found'
In my original code, I tried to add more light:
light = bpy.data.objects["Lamp"]
light.location = (-12, 0, 0)
look_at(light, Vector((0.0, 0, 0)))
bpy.data.lamps['Lamp'].type = "HEMI"
bpy.data.lamps['Lamp'].energy = 10
bpy.data.lamps['Lamp'].use_specular = False
bpy.data.lamps['Lamp'].use_diffuse = True
KeyError: 'bpy_prop_collection[key]: key "Lamp" not found'
b1bb2
Postby b1bb2 » Sat Sep 25, 2021 6:45 am
I fixed it. There are still a few minor bugs. Thanks for your help.
# camera.bpy  b1bb2  2021 09 24
# /home/bullseye/blender/2.93.1/extract/blender-2.93.1-linux-x64/blender -P /home/bullseye/blender/2.93.1/bpy/camera.bpy
# in GUI:
# x axis is red
# y axis is green
import bpy
from math import pi
bpy.context.scene.render.filepath='/home/bullseye/blender/2.93.1/png/camera/start.png'
# add two cones to make a good scene
bpy.ops.mesh.primitive_cone_add(location=(2.0, 0.0, 0.0), scale=(1.0, 1.0, 1.0))
bpy.ops.mesh.primitive_cone_add(location=(-2.0, 0.0, 0.0), rotation=(pi/4, 0.0, 0.0), scale=(1.0, 1.0, 1.0))
bpy.context.scene.render.filepath='/home/bullseye/blender/2.93.1/png/camera/cones.png'
# remove default light
bpy.ops.object.select_by_type(type='LIGHT')
# remove default camera
# more cameras are needed.
# object names should be used.
bpy.ops.object.light_add(location=(+12.0, 0.0, 0.0))
bpy.context.object.data.energy = 500
bpy.context.object.data.name="light_px"
bpy.context.object.data.name="camerapxabouty"
bpy.context.scene.render.filepath='/home/bullseye/blender/2.93.1/png/camera/camerapxabouty.png'
bpy.ops.object.light_add(location=(-12.0, 0.0, 0.0))
bpy.context.object.data.name="light_nx"
bpy.context.object.data.name="cameranxabouty"
bpy.context.scene.render.filepath='/home/bullseye/blender/2.93.1/png/camera/cameranxabouty.png'
bpy.ops.object.light_add(location=(0.0, 0.0, +12.0))
bpy.context.object.data.name="light_pz"
bpy.context.object.data.name="camerapz"
bpy.context.scene.render.filepath='/home/bullseye/blender/2.93.1/png/camera/camerapz.png'
bpy.ops.object.light_add(location=(0.0, 0.0, -12.0))
bpy.context.object.data.name="light_nz"
bpy.context.object.data.name="cameranzaboutx"
bpy.context.scene.render.filepath='/home/bullseye/blender/2.93.1/png/camera/cameranzaboutx.png'
bpy.context.object.data.name="cameranzabouty"
bpy.context.scene.render.filepath='/home/bullseye/blender/2.93.1/png/camera/cameranzabouty.png'
b1bb2
Return to Blender and MPFB
