MK for blender plugin does not work
Postby jpujolar » Fri Jul 17, 2020 3:57 pm
Dear friends,
I have installed today's latest builds of MH and Blender. I got the MakeSkin, Makerclothes and Maketarget2 plugins installed with no issues; but "makehuman-plugin-for-blender.zip" has issues:
The "import human" button does not work. The following message appears:
Connection Refused
Cannot connect to MakeHuman App!
Check Settings in MPFB and MakeHuman
Check Security settings of the OS
The same message appears if you click "Sync with MH". This is with a Windows 10 plaform. A PC.
jpujolar
Re: MK for blender plugin does not work
Postby loki1950 » Fri Jul 17, 2020 4:38 pm
Stupid question is makehuman also running(it should be) then check the Community/Socket tab make sure Accept connections is checked.
Postby jpujolar » Fri Jul 17, 2020 5:34 pm
loki1950 wrote:Stupid question is makehuman also running(it should be) then check the Community/Socket tab make sure Accept connections is checked.
That was it, thanks. I tried to find references to this in the documentation or tutorials; but had not found it. Awesome :D
jpujolar
Return to Blender
