Eyebrows/Eyelashes problem
Postby kingofnoodles5 » Wed Jul 08, 2020 9:46 pm
I'm new with this. When I imported my model, the eyelashes and eyebrows were solid. Basically 1 color, no transparency. Can someone help me?
Note: I'm using Blender 2.82.
Last edited by kingofnoodles5 on Thu Jul 09, 2020 11:58 pm, edited 1 time in total.
kingofnoodles5
Re: Eyebrows/Eyelashes problem
Postby loki1950 » Thu Jul 09, 2020 12:25 am
Not very much info here like how are you importing into blender if .dae or fbx you will have issues with materials they are detailed in the wiki the "Docs & FAQ" link in the header,mhx2 does a much better job of export/import.
Postby MTKnife » Thu Jul 09, 2020 5:03 pm
Try setting them as transparent in Blender. I know I've always had to do this, though I haven't used the latest version of the importer yet.
MTKnife
Postby kingofnoodles5 » Thu Jul 09, 2020 11:59 pm
loki1950 wrote:Not very much info here like how are you importing into blender if .dae or fbx you will have issues with materials they are detailed in the wiki the "Docs & FAQ" link in the header,mhx2 does a much better job of export/import.
I used FBX.
kingofnoodles5
Postby loki1950 » Fri Jul 10, 2020 1:23 am
Our fbx exporter is not that good if you need fbx later in your tool chain use the blender exporter as they have a link with fbx's owners Autodesk use mhx2 to move from makehuman to blender.
Return to Blender
