Need eyebrow material
Postby Anstrah » Mon Jun 19, 2023 10:46 am
Hello,
Could you tell me if there are other material for the eyebrows included in MakeHuman's base package, especially for the eyebrows 001?
If there are not other material, I would like to create it by modify the image of the texture but I don't find it: I find in my documents the assets I downloaded, but not those in the base package... Could you tell me how I can find them, please?
Thank you in advance!
Anstrah
Re: Need eyebrow material
Postby tomcat » Mon Jun 19, 2023 11:38 am
Anstrah wrote:I find in my documents the assets I downloaded, but not those in the base package... Could you tell me how I can find them, please?
The standard assets are in the folder of the installed program:
..\makehuman-community\makehuman\data
Postby RobBaer » Tue Jun 20, 2023 3:05 am
Anstrah wrote:Hello,
The answer is no as you can find out by clicking on the material>skin/material tab and then checking eyebrows on the left.
One possibility is to create your own material by choosing utilities > material editor and choosing eyebrows which will be available on the left if you have added eyebrows. In case you dont see the editor (which is not enabed bt default), choose settings>plugins and check it under number 7. Then restaart MH.
Postby Anstrah » Wed Jun 21, 2023 2:48 pm
RobBaer wrote:One possibility is to create your own material by choosing utilities > material editor and choosing eyebrows which will be available on the left if you have added eyebrows. In case you dont see the editor (which is not enabed bt default), choose settings>plugins and check it under number 7. Then restaart MH.
Thank you very much! I didn't now there was a material editor! Could you tell me if there is a tutorial to use it? I have found the material editor, but I don't understand how to use it... I want to change the color of the eyebrows but I don't understand how to do it...
Anstrah
