File path error with node id 67 slave collar full metal
PostPosted: Sun Dec 29, 2019 3:22 pm
by yumri23
Makehuman 1.2.0 alpha 4 works fine until I use the community asset Node id 67 author learning license CC0 title Salve collar full metal. When I use that asset I get the error
Cannot get texture for file path Tileable+eroded+scratch+metal+background+05.jpg. no such file.
In the Logs tab under Utilities. It goes away when the asset is removed. It happens even if the process is repeated with a reset of the 3D model then the Salve collar full metal is applied. In that I concluded it is that asset.
Please fix.
