Skins - UV BASE map for ?
I was wanting to attempt to create a custom skin for Make Human. (My intended base model is attached.) (The idea was to create a sci-fi character, partly inspired by the origin story of the Cybermen in Doctor Who. My thought was to consider what you would get if you had Cyber-femme instead?
Would it be possible for a Makehuman user to provide a suitable UV map (prefferably in a 2K(2048x2048) or 4K(1096x4096) size, so I can use that as a base for constructing the skin as Vector artwork in Inkscape ( possibly with meshes?), That could then be exported.
Alternatively, is there a specialist standalone MakeSkin tool, to enable re-skinning based on arbitary underlying tectures?
Please note that the attached model uses the custom Robot01 target contributed by Grinsegold (which is available under the CC-BY license from the Make Human asset repository.)
