Problem with My New Skirt
Re: Problem with My New Skirt
Postby MTKnife » Thu Sep 19, 2019 1:26 am
OK, I see now I was misreading the warning I get when I export it with MakeClothes: it tells me I have more than 8 poles, not 8--and my max is actually 16. It's already at 16 in the MHCLO file, so I'm guessing no one has yet fixed the problem that requires a higher "max_pole" value for tris--though apparently double isn't required, since you got it to working with 24. I've changed it to 24 in my version and re-uploaded. Everyone who's interested in the skirt: pease try downloading it again and tell me whether or not it works for you.
MTKnife
Postby Marco_105 » Thu Sep 26, 2019 3:29 am
Yes, that work for me also, change amx_pole, I saw somebody to speaking about that in the forum.
Marco_105
Postby MTKnife » Thu Sep 26, 2019 3:55 am
Thanks for confirming it.
MTKnife
Postby Mira23 » Thu Aug 25, 2022 3:48 am
naflatem wrote:Hi,
I had the same issue.
Changed the max-pole in mhclo-file to 24. Than it worked and created the .npz file.
Thanks for this wonderfull asset.
Naflatem
I think your method is very good, thank you for sharing venge io
smash karts
Mira23
