body normalmaps
PostPosted: Sat May 11, 2019 2:25 pm
by pitibonom
Hi :)
I'm struggling for getting male and female bodies normalmaps :(
Is there somewhere i can find some ?
maybe some MH users created some that they could share here .
This would be great !
thanks in advance :)
Re: body normalmaps
PostPosted: Sat May 11, 2019 4:50 pm
by loki1950
There are several threads here on the forum that have normal maps for the body use the search function ;)
Re: body normalmaps
PostPosted: Wed May 15, 2019 11:41 am
by bogdan666
There is a "trick" for better mesh/texture appearance even without a normal map. Just create a MH Character (woman etc.), then adjust the target sliders (Modelling-->Custom panel): For example maximize "Armpit", "Foot_achilles_tendon", "Foot_malleolus_lateral", "Foot_malleolus_medial" and "Shoulder_shape" etc. (for a good base model mesh) Then in blender use the subsurf modifier and apply it before the armature and your character will end up with better looking feet/ankles, armpits and clavicle, but it comes at a price: ca. 135~ triangles. That shouldn't be a problem for a main character in a game engine (and even less of a problem in blender), if you have a good pc. It's a pretty good base for further work, then add a 4k texture to it and voila!
4k skin: viewtopic.php?f=2&t=15545&start=80
As for the normal map I can't help, because I haven't found any decent/realistic ones so far.
But as far as I understand normal maps are based on a resculpted (subtraction sculpting?) high poly mesh, whose details are baked onto a lower resolution mesh in blender. I've done that once and it worked technically, but looked like sh..... :-)
