Downloaded assets display odd orange/black label
Postby pk84 » Thu Dec 07, 2017 9:12 pm
So I am new with make human and hope this is an easy fix.
I download the "female skinsuit 01 make human" and when I go to makehuman-->materials--?skin/material-->it displays itself in the sidebar of material with the correct image; so far so good.
When I click it through, and the goes over to my human, she is cover in some shaded orange and black with some white letters on them (can't read them) instead of the correct display like seen on the sidebar. The shape of the structure remains accurate.
I tried other skins/material and even clothes assets and the same label shows. Any thoughts?
I am on a MacBook, MacOS version 10.13.1 if that matters.
pk84
Re: Downloaded assets display odd orange/black label
Postby joepal » Thu Dec 07, 2017 9:20 pm
It's the image saying (I think) "texture not found" or "file not found". This is most likely because the texture file (the .png or .jpg image) and the material descriptor (.mhmat file) aren't in the same directory, because the image is misnamed, or because of a mistake in the mhmat file.
You can open the mhmat file (it's just a text file) and look for a line saying "diffuseTexture ..." and check that the file name mentioned there is the same as the image file you should have downloaded.
Postby loki1950 » Thu Dec 07, 2017 10:32 pm
Or you can use the Material Editor plug-in which comes with makehuman's download it's found on the Utilities tab.
Postby pk84 » Fri Dec 08, 2017 4:51 pm
Okay so I tried shortbodysuit and opened the mhmat file as a txt and got this below. Does anyone see an issue within it?
# Material definition for shortbodysuit
name shortbodysuit
description shortbodysuit material
ambientColor 0.505882352941 0.505882352941 0.505882352941
diffuseColor 1.0 1.0 1.0
specularColor 0.113725490196 0.113725490196 0.113725490196
shininess 0.1961
emissiveColor 0.0 0.0 0.0
opacity 1.0
translucency 0.0
shadeless False
wireframe False
transparent False
alphaToCoverage True
backfaceCull True
depthless False
castShadows True
receiveShadows True
normalmapIntensity 1.0
shader shaders/glsl/litsphere
shaderParam litsphereTexture litspheres/lit_leather.png
shaderConfig ambientOcclusion True
shaderConfig normal True
shaderConfig bump False
shaderConfig displacement False
shaderConfig vertexColors False
shaderConfig spec False
shaderConfig transparency True
shaderConfig diffuse True
pk84
Postby pk84 » Fri Dec 08, 2017 4:57 pm
And I am sure what the procedure is by going into Ultities to find a plugin. All I see with "material" is under message-->loading/unloading or imported/importing plugin3_libraries_materials_chooser
pk84
Postby Aranuvir » Fri Dec 08, 2017 5:03 pm
Did you download the images "shortbodysuit.png" and "shortbodysuit_normals.png", too?
Postby pk84 » Fri Dec 08, 2017 5:39 pm
I did not download the Normals file and that seemed to have worked, the skin/clothes are visible now.
I Knew it Had to be Something Simple!! THANK YOU! :)
pk84
Postby loki1950 » Fri Dec 08, 2017 5:55 pm
pk84 wrote:I did not download the Normals file and that seemed to have worked, the skin/clothes are visible now.
We all have our Homer moments DoH as for the Materials Editor it may not be activated check Settings-->Plugins if not just click on the box beside 7_material_editor.
