joepal wrote:We had archive.makehuman.org a while back, but it dropped off the net in the makehuman.org / makehumancommunity.org split.
I've restored it at http://files.jwp.se/archive/. If it doesn't answer when you try, then wait an hour and try again. I just changed the DNS record for this, so it might take a while to propagate.
I think most of the older (pre 1.0) releases simply bundled all assets without any compilation, so the obj files should be in there unchanged.
I might be confused, but for alpha 8, I think that wasn't actually released. When people speak about alpha 8, they probably mean a nightly build from the period when we were discussing releasing a8. As I remember it, we finally decided calling that 1.0 instead.
But if I'm wrong, I'd welcome someone sending me the a8 release and I'll add it to the archive too.
You're in luck! Here is the a8 release from 2013:
http://www.geekopolis.ca/apps/makehumansvn-6546-win32.zip
and, as a special surprise, a51 from 2011:
http://www.geekopolis.ca/apps/makehuman-nightly-linux-feb182011-i386.tbz2
