some of the old versions of make human have a really nice skirts.shoes,hair, and even underwear for female
will it be possible that someone that know how, to could post them in the hair body extensions comunity?
IT will be great!!!
thanks
badwolf wrote:it would be something of a nightmare due to the differences between the meshes.
it might be possible to given the mesh from the old clothing to pull the mesh into Blender do needed patching and then rebuild the clothing file
INVOKE Joepal: how could somebody get a hold of an "Offical" copy of the older assets??
joepal wrote:We had archive.makehuman.org a while back, but it dropped off the net in the makehuman.org / makehumancommunity.org split.
I've restored it at http://files.jwp.se/archive/. If it doesn't answer when you try, then wait an hour and try again. I just changed the DNS record for this, so it might take a while to propagate.
badwolf wrote:the windows copies can be unpacked without actually running them correct??
I think most of the older (pre 1.0) releases simply bundled all assets without any compilation, so the obj files should be in there unchanged.
I might be confused, but for alpha 8, I think that wasn't actually released. When people speak about alpha 8, they probably mean a nightly build from the period when we were discussing releasing a8. As I remember it, we finally decided calling that 1.0 instead.
But if I'm wrong, I'd welcome someone sending me the a8 release and I'll add it to the archive too.
joepal wrote:badwolf wrote:the windows copies can be unpacked without actually running them correct??
I think the *.exe files are installers. So if you're only after certain files, you're better off installing 7-zip or something that is able to read tarballs and then download the tbz2 files.
