okay setup is the default female tights layer remapped (to make later texture work easier).
im going to be cutting parts out to make some clothing but some of the cutting is going to be tricky (existing verts not in the "correct place)
my first tricky cut is the leg openings (for a leotard and lower basque)
https://dl.dropboxusercontent.com/u/539 ... hell.blend
i have an object in the correct place but does anybody know of a decent way to make the cuts?? (note i will be needing help with at least the arm holes later)
