Page 1 of 2
Makeup for the Ladies
Posted:
Mon Jan 30, 2012 4:39 pm
by Arcadia
I've created some makeup - Textures for the Makehuman Ladies
The zip contains a psd and xcf layer file with Eyeliner, Eyeshadow, Lips, freckels and so on. Just copy them over your favourite Texture, play around with colors, mix or used them as a guide for your own creations, and finally save them under a new Name in the Skin folder.
Hope you like it
You can download them here:
http://min.us/m2C7pe6AW#1o
Re: Makeup for the Ladies
Posted:
Mon Jan 30, 2012 10:43 pm
by duststorm
It would be a nice feature if MakeHuman allowed to add additional skin layers on top of each other, and for example let you adjust their opacity.
Nice, though, in my opinion the colors are a bit too bright. Maybe you could roll back the opacity a bit, make the underlying skin pattern shine through a bit more. That way it would look more like it is applied to the skin, rather than pasted on like a sticker. Maybe also try blurring and fading out the outer purple edges of the makeup a bit, they look a bit too sharp and perfect.
Posted:
Tue Jan 31, 2012 2:34 am
by mflerackers
This feature already exists, but has yet to be documented and finished. It is used for example for the eyes library tab.
You define layers in an mhstx (subtexture) file as follows
{ 'txt': 'green-left.png', 'dst': (470, 1783) },
{ 'txt': 'green-right.png', 'dst': (1803, 1546) }
with txt (texture) an image file and dst (destination) the position it needs to be copied to. Several textures can be used in one layer to reduce the size. The reason this is not documented yet is because we are still working on it, so the format might still change. Also there is still a minor bug, the alpha channel overwrites instead of blends with the base texture, this will be fixed shortly.
Posted:
Tue Jan 31, 2012 7:09 am
by mflerackers
The aforementioned bug has been fixed in svn, but the official exe still needs to be recompiled.
Posted:
Tue Jan 31, 2012 8:06 am
by duststorm
Maybe the makeup is a good way to demonstrate its use.
Do I understand it correctly that you place smaller PNGs on top of the original texture and specify their position? I suppose this way you avoid wasting space on a large texture with a lot of transparency (although maybe PNG would compress that very well)
So is one unit of PNGs between brackets handled as one single layer in MH or are those all separate layers?
Posted:
Tue Jan 31, 2012 8:21 am
by mflerackers
one mhstx can contain several png's to reduce space yes, but they represent one layer.
Posted:
Wed Feb 01, 2012 8:28 pm
by Arcadia
duststorm wrote:It would be a nice feature if MakeHuman allowed to add additional skin layers on top of each other, and for example let you adjust their opacity.
Thx for your Comment - I Know, the makeup on the image is quite heavy, but only for demonstration-purposes.
You can change the Opacity, Colors & visibility of the layers, like you want to have it. You can use all Layers ( like in the image) or even one, maybe the Eyeliner or the Lips.
Posted:
Wed Feb 01, 2012 10:51 pm
by Kiibakun
Posted:
Mon Mar 05, 2012 6:07 pm
by robertltux
btw do you mind if i used your file for a skin template??
I have added a skin layer a leotard layer and a "BlackSwan" mask layer to the file.
It may not be high art but it does work fairly well.
Posted:
Wed Mar 07, 2012 1:31 pm
by Arcadia
robertltux wrote:btw do you mind if i used your file for a skin template??
No problem
