Mindfront wrote:Eye candy
This is most inspiring impressive great work. All this details... the expressions and poses... I just saw your Wireless Headset and that is
To pose Leska directly on the left side of the camera looking through the viewfinder not intersecting the pod of the stand and also turning the wheel of the swivel mechanism was really hard
In normal life you can also use a display on the cameras instead of the viewfinder. This would make the scene simpler ...
loki1950 wrote:Like the way you branded the camera and rig
This is intended. Well you only have to change the 4 letters of DUCK ... unfortunately I cannot asked Mr. ARnold and Mr. RIchter (they allready died, because the company is existing since 100 years) if I'm allowed to put the real brand on the camera and since Leska handles the camera, I call her Aleska ... So no commercials here.
But on the other hand, you can only rent this camera and I was fascinated when I saw this device. Just to be fair: I know there is another company in California also creating great cameras ...
RobBaer wrote:Love the modeling work and the time you spend on research shows in your final product. Kudos!
Thanks! I first thought of buying one of these cameras just to measure the dimensions ...
wolgade wrote: Ok, in this case...
I did that, just to test you.
No I was too lazy to fix it again and again. The cables are 3 Bezier-curves fixed to a few hooks, one is directly inside the ring holding the wires. But even then, when you swivel or tilt the camera a bit, the cables move outside the ring. Best way of course is to fix that directly before you render. Since yesterday, you can try that with your copy
