MakeHuman doesn't work on Big Sur mac os
Postby Baryafe » Sat Nov 14, 2020 5:07 pm
hello,
recently I updated my mac to version 11.0.1 macOS Big Sur.
the MakeHuman doesn't open anymore.
any idea why?
Baryafe
Re: MakeHuman doesn't work on Big Sur mac os
Postby MTKnife » Sun Nov 15, 2020 12:28 am
I assume you're still running 1.1.1? Given that MacOS is no longer supported for the latest version of MH (1.2), I suppose it was inevitable that eventually a new version of MacOS would break it.
MTKnife
Postby Baryafe » Sun Nov 15, 2020 3:57 am
I see.
So will I have to wait for another version?
Baryafe
Postby jwc » Sun Nov 15, 2020 6:56 am
Are you sure that MakeHuman was given permission under the System Preferences, Security & Privacy, General tab?
Some people have not been able to run the program because of this requirement.
It is possible to install the latest MakeHuman 1.2.0 release from the source code.
This is known to work up to Catalina (10.15.7)
If you follow the source install instructions at
https://github.com/makehumancommunity/makehuman
and the program still does not start, please post some additional information about the failure.
One issue not addressed in the installation instructions: If you have a problem using the old PyQt5 library version, then installing in a virtual environment is suggested.
There are some issues with creating an macOS installer package, including Apple's notarization requirements.
jwc
Postby Baryafe » Sun Nov 15, 2020 7:00 am
I did, and tried the version 12.
didn't work.
Baryafe
Postby jwc » Mon Nov 16, 2020 5:32 am
When you run MakeHuman 1.2 from the command line, what output is produced?
jwc
