Adding new bones to skeletons
Postby porky11 » Thu Jun 08, 2017 9:30 am
Is there already some way to add new bones to a skeleton in makehuman (better than writing .json-files manually)?
Would be useful for charakters with a tail or tentacle hair or whatever.
porky11
Re: Adding new bones to skeletons
Postby RobBaer » Sat Jun 10, 2017 3:12 pm
porky11 wrote:Is there already some way to add new bones to a skeleton in makehuman (better than writing .json-files manually)?
No. MH works at the level of skeletons not bones. You could make a variation on an existing skeleton in a program like Blender (preferably the default skeleton which is the one that drives things inside MH itself) and add an additional bone. Like any other new skeleton, it would need to be weighted for the MH mesh and coordinated to the default skeleton to honor built in sliders.
Postby porky11 » Sat Jun 17, 2017 11:58 pm
That's what I already know. My problem is, how to load a skeleton, connect it to the default human and export it.
I probably just found out, how to export it when loading some finished human with a skeleton, some new options in maketarget appear, also exporting rigs, but it does not work with this mesh.
porky11
Postby Aranuvir » Sun Jun 18, 2017 7:51 am
If I get your question correctly: There is no direct functionality to use other skeleton than the skeletons that were built-in.There is an undocumented (and unsupported) blender tool that lets you create json files for an edited/new skeleton, though this json file needs to be heavily tweaked by hand afterwards. Use the search function of the forum for more information.
Postby blindsaypatten » Sun Jun 18, 2017 3:09 pm
Perhaps you can elaborate on your workflow. You create a character in MH. You export it and import it in Blender, you add the bone. What exactly do you then want to do with it?
Postby RobBaer » Wed Jun 21, 2017 2:44 pm
porky11 wrote:... how to load a skeleton, connect it to the default human and export it.
Looking again I see your interest is "tails". Everything inside MH (pose-wise) is driven by the default skeleton. The other skeletons are derived at export time. The default skeleton does not have a tail so tails are best implemented downstream in your animation program, e.g., Blender. Nothing keeps you from creating a mesh proxy to be accommodated by an alternate downstream rig.
Postby brkurt » Wed Jun 21, 2017 7:25 pm
I've only done this a couple of times, but it is possible in Blender 2.7x to parent one armature to another. This is very useful for creating wigs, that can quickly be changed from one animation to another. An example would be Wonder Woman with a rigged braid wig, then a rigged loose long hair wig.
A nice feature of this parenting approach is that one rig can be strictly FK (I need this for martial arts and facial expression animations) and one rig can have FK and IK, such a swinging braid or tail.
Postby porky11 » Sun Jun 25, 2017 4:56 pm
blindsaypatten wrote:Perhaps you can elaborate on your workflow. You create a character in MH. You export it and import it in Blender, you add the bone. What exactly do you then want to do with it?
Depends on the character. For example, when I add a Tail, I'd like to be able to animate the tail too, (similar to animating a Arm or leg)
porky11
