Penis sliders don't work for self defined penis
Postby porky11 » Mon Jun 05, 2017 6:52 pm
I made a new penis proxy and it works as expected, but the sliders are disabled.
The sliders only work, when I use the adult_male_genitalia from the user contributed assets.
After editing the sliders, and changing back to my own penis proxy, the size has changed as expected.
What did I do wrong?
porky11
Re: Penis sliders don't work for self defined penis
Postby joepal » Tue Jun 06, 2017 7:25 am
You need to add a tag to the descriptor file (the ".proxy" file).
The relevant piece of code for determining if a proxy is considered "with genitals" and should enable the sliders is this:
    def hasGenitals(self):
        Determines whether the human model has genitals geometry.
        Genitals geometry is present if the proxy (alt. topology)
        has the tag "genitals" assinged (convention).
        if self.isProxied():
            if 'genitals' in self.proxy.tags or 'Genitals' in self.proxy.tags:
                return True
        return False
If you take a look in http://www.makehumancommunity.org/sites ... alia.proxy, line 7, you can see how it's supposed to look.
Postby porky11 » Tue Jun 06, 2017 8:12 pm
Thanks, works now
porky11
