Add my Custom Rig and Assign vertices
Postby O_J » Tue Feb 28, 2017 1:21 am
Hi all, I have my bvh Rig found here https://www.dropbox.com/s/m8z6cr2q3mbd3q7/MyRig.bvh?dl=0. I want to Add it to the makehuman rigs and assign correct vertices to each bone to be able to export good deformed meshes.
What I did is that I navigated to the rigs folder, then made a copy of both cmu_mb.mhskel and cmu_mb.thumb and renamed them to myrig_mb.mhskel and myrig_mb.mhskel. I'm not sure what to do next to correctly create myrig and fits the human model correctly on it. Any advice please? Thank you.
O_J
Re: Add my Custom Rig and Assign vertices
Postby RobBaer » Wed Mar 01, 2017 9:10 am
It's not clear to me what you are asking.
.bvh files contain animations for a bone hierarchy and are used in single frame format within MH to specify poses. The way to pose an MH character is to use the MakeHuman Blender tool called Makewalk in conjunction with an existing .bvh file pose for a similar skeleton to apply the pose to the MakeHuman figure.
If instead, you have posed an MH figure in blender with the default rig, you would export the pose as .bvh, saving it to c:/%user%/documents/makehuman/v1/data/poses (on Windows), and then creating a .thumb file (png format) and an appropriate metadata file which are savedin the same folder. This is usable within MH.
If you have a new skeleton hierarchy stored but a standard A pose for which you want to create rig weights to the MakeHuman mesh, you will have to do that outside MakeHuman, for example in Blender.
Postby O_J » Wed Mar 01, 2017 1:06 pm
RobBaer wrote:It's not clear to me what you are asking.
I'm just using the bvh file as I want to have my own rig inside makehuman. So I navigated to the rigs folder, then made a copy of both cmu_mb.mhskel and cmu_mb.thumb and renamed them to myrig_mb.mhskel and myrig_mb.mhskel. So now if I open makehuman there will be two identical rigs one cmu and one myrig. Now I want to know how to use the structure of mybvh to construct the rig of myrig in makehuman instead of the cmu rig? and how to assign the correct vertices of the model to the correct bone of rig so that deformations looks good?
O_J
Postby RobBaer » Wed Mar 01, 2017 7:48 pm
O_J wrote:I'm just using the bvh file as I want to have my own rig inside makehuman. So I navigated to the rigs folder, then made a copy of both cmu_mb.mhskel and cmu_mb.thumb and renamed them to myrig_mb.mhskel and myrig_mb.mhskel. So now if I open makehuman there will be two identical rigs one cmu and one myrig. Now I want to know how to use the structure of mybvh to construct the rig of myrig in makehuman instead of the cmu rig? and how to assign the correct vertices of the model to the correct bone of rig so that deformations looks good?
MakeHuman is not used for rigging. The cmu rig is made especially to work with the .bvh animations in the carnegie-melon collection and also works well with the female AACAD collection. It was meticulously fit to the MakeHuman mesh in Blender. Rigging is a very complex process well beyond the scope of this forum. You can find a variety of tutorials for Blender rigging (and probably other 3D software rigging) on the web. Try googling "rigging in Blender"
Postby O_J » Thu Mar 02, 2017 6:28 am
RobBaer wrote:MakeHuman is not used for rigging. The cmu rig is made especially to work with the .bvh animations in the carnegie-melon collection and also works well with the female AACAD collection. It was meticulously fit to the MakeHuman mesh in Blender. Rigging is a very complex process well beyond the scope of this forum. You can find a variety of tutorials for Blender rigging (and probably other 3D software rigging) on the web. Try googling "rigging in Blender"
I'm still not sure if you understand what I want to do or what the problem with my question is? I want to set my own skeleton in makehuman and adjust it's weights properly to be able to export meshes from it directly without the need of blender to do that, just set up the skeleton once here with correct mesh/bone weighting and use it, but I'm not sure how it can be done, that's why I'm asking for help and assistance.
O_J
Postby joepal » Thu Mar 02, 2017 8:54 am
Creating a makehuman skeleton is a somewhat intimidating task, largely because the tools are very much not user friendly, and mostly undocumented.
You would need to produce a .mhskel file (for the rig as such) and (optionally) a .mhw file (for the weight painting).
You can take a look at how the game engine skeleton look here: https://github.com/makehumancommunity/o ... ine.mhskel
The only tool for this is "io_mhrigging_mhskel" in the makehuman-utils repo: https://bitbucket.org/MakeHuman/makehuman-utils. This is a blender plugin which adds a mhskel export option in blender.
Running this, you can create a crude, unfinished mhskel file. You will still need to edit this manually (with a text editor) to remove null values for rotations that the exporter script could not figure out automatically.
