Need artist/blender help for next release
Re: Need artist/blender help for next release
Postby joepal » Tue Jan 24, 2017 12:40 pm
You should be allowed to attach blender files to posts here.
Postby Marco_105 » Tue Jan 24, 2017 1:41 pm
Okay Joel I try to upload it !
FIX_work_suit_finalised.blend
(18.83 MiB) Downloaded 157 times
Marco_105
Postby joepal » Tue Jan 31, 2017 11:13 am
@marco: Looking at this, it seems there are pretty large changes. Before merging I just want to make sure I understand:
Is it correct that you've remade the entire UV layout from scratch and that this is basically a new asset based on the old one? As in, there is not only minor touch-up on the original diffuse texture?
Also, it seems that the human object in the scene isn't an unmodified base mesh, meaning that there is no delete group etc available.
To compare:
Original worksuit diffuse
The diffuse texture from the blend
Postby Marco_105 » Wed Feb 01, 2017 11:00 am
yes, because that was impossible to do otherwise.
I upload the BL file like that and I did think you have to made the group as you like.
I could make it if you want and if you give me rules for did it.
Marco_105
Postby joepal » Wed Feb 01, 2017 1:22 pm
Maybe you could do the whole makeclothes process and upload the files it produces?
Postby Marco_105 » Wed Feb 01, 2017 6:37 pm
Don't know how you want this process built with for your specific assets, this is for that i give the BL file...
Marco_105
Postby Marco_105 » Wed Feb 01, 2017 7:55 pm
So I send it with delete group, hope that will fine...
I cannot send .mhclo there!
Marco_105
Postby joepal » Wed Feb 01, 2017 8:19 pm
You can upload it as a new item in the assets repo at http://www.makehumancommunity.org/clothes.html. Then I can fetch it from there.
Postby Marco_105 » Thu Feb 02, 2017 5:11 am
Look at UCA Working_suit Joel.
Marco_105
Postby joepal » Sun Feb 05, 2017 11:22 am
Ok, thanks. Yes, it looks a lot better when comparing them side by side.
I've accepted your version with minor changes in file names etc. It's uploaded to the main assets dir now, so it will appear in the next build.
