New area for collaborative work
Postby joepal » Mon Jan 04, 2016 9:37 am
As the forums is a very cumbersome way to share files, I've now opened up a github repo for sharing WIP assets:
https://github.com/makehumancommunity/c ... assets-wip
Upside is you get everything managed this way. Downside is you'll have to learn the basics of git. There are plenty of tutorials on the net. TL;DR, simply download https://tortoisegit.org/download/ if you're on windows.
The repo is a bit experimental. In particular, there is a size limit for github repos, so it's possible it might have to be split in sub-sections if lots of material end up there.
Re: New area for collaborative work
Postby brkurt » Mon Jan 04, 2016 5:47 pm
joepal wrote:As the forums is a very cumbersome way to share files, I've now opened up a github repo for sharing WIP assets:
Many thanks! My extra-fine eyelashes and eyebrows continually crash MakeClothes, and I know that other users need them, as they remove the need for fancy rendering tricks. :)
Postby learning » Mon Jan 04, 2016 8:57 pm
Nice idea. Can someone maybe point me to some "git for total dummies" tutorial?
learning
Postby loki1950 » Mon Jan 04, 2016 9:33 pm
learning wrote:Nice idea. Can someone maybe point me to some "git for total dummies" tutorial?
Under which OS as the tools available differ greatly Linux has the most as git was first developed by Linus Torvalds for use in development of the Linux kernel itself(commercial program they where using started demanding payment) git usage is fairly simple most of the kernel hackers like the command line :( so GUI's for git are primitive at best.
Postby learning » Wed Jan 06, 2016 3:02 am
Of course I mean GNU/Linux, as far as I'm concerned that's the only OS that's usable on PCs. I'm not scared of command line, it's reading long mans that scares me :)
learning
Postby loki1950 » Wed Jan 06, 2016 4:54 am
The man page for git is not that long and not too convoluted the main commands are push and pull and some maintenance functions so if the man page confuses you have look at https://help.github.com/ good fac and setup info as well.
Postby Marco_105 » Mon Jan 11, 2016 6:41 am
Very good way to manage assets and update it !
Marco_105
Postby jcpalmer » Mon Jan 11, 2016 4:52 pm
Here is a git intro, which assumes you have command linehttp://git-scm.com/book/en/v1/Getting-Started git. I do not remember if Linux comes with git, but if not and you type git on a console, it should ask to install it.
There are also many front ends. I use Eclipse, but I am coding python / Typescript / Java.
If you plan to contribute via Pull request, PR, then you will need to fork the repository to your own account. See this. https://help.github.com/articles/fork-a-repo/
jcpalmer
