cannot import mhx2 MH file into Blender 2.9
Postby lvartist0042 » Thu Nov 19, 2020 9:05 pm
Until recently I was using Blender 2.8. No problem importing a MH mxh2 file into 2.8. I now downloaded Blender 2.9. The mhx2 addon does not work in 2.9. The addon is listed in the Blender preferences addons. However the mhx2 file format is not listed as an import option.
Does a new plugin exist? So far I cannot find one.
Thanks
lvartist0042
Re: cannot import mhx2 MH file into Blender 2.9
Postby Aranuvir » Thu Nov 19, 2020 9:53 pm
Maybe you are confusing Makehuman Plugin for Blender and the MHX2 add-on?
Postby lvartist0042 » Thu Nov 19, 2020 10:55 pm
Aranuvir wrote:Maybe you are confusing Makehuman Plugin for Blender and the MHX2 add-on?
Thanks, you are probably correct. I want to export a MH file in mhx2 format. Then open Blender and import the same mhx2 file.
At this link: http://www.makehumancommunity.org/content/plugins.html
Am I correct to assume that I want this file: MHX2 (blender side) (download zip) that goes into the Blender Addon folder?
Thanks
lvartist0042
Postby loki1950 » Fri Nov 20, 2020 4:28 am
Yes and you can use the zip file as well you can leave it in your download folder just browse to it after hitting the "Install from file" button on the add-on tab of the blender preferences window.
Postby lvartist0042 » Fri Nov 20, 2020 3:36 pm
Thanks. Problem fixed this AM in less than 60 seconds. Import function working perfectly. Thought I did this yesterday several times. Likely a brain cell malfunction!!
Thanks for your help. Much appreciated.
Michael
lvartist0042
Postby loki1950 » Fri Nov 20, 2020 6:11 pm
No problem what we're here for we all have Homer moments :lol: if you run into further issues just post a question.
