New intro anim
Re: New intro anim
Postby grinsegold » Sat Aug 05, 2017 2:54 am
joepal wrote:Any suggestions for improvements?
0001-0250.avi
(2.44 MiB) Downloaded 591 times
Could you provide a font template for an alpha over please?
grinsegold
Re: New intro anim
Postby joepal » Sun Aug 06, 2017 3:42 pm
The logo is an SVG image, which I've imported as mesh into blender.
I'll attach my .blend and the svg in case someone wants to take a swipe at their own version of an intro anim.
The transitions are done via keyframes in the node settings for the materials of the objects which need to fade in/out. I guess this might take a while to figure out if you're unfamiliar with that approach.
introscreen.svg
(9.7 KiB) Downloaded 515 times
IntroAnim.blend
(19.31 MiB) Downloaded 381 times
Re: New intro anim
Postby grinsegold » Mon Aug 07, 2017 10:03 am
How's that?
0001-0250.avi
(3.91 MiB) Downloaded 418 times
grinsegold
Re: New intro anim
Postby joepal » Mon Aug 07, 2017 2:10 pm
That looks very nice.
If you're comfortable with it, maybe you could attach the blend, and I'll add the URL etc?
Re: New intro anim
Postby grinsegold » Mon Aug 07, 2017 8:18 pm
Sure!
MH morph.blend
(48.55 MiB) Downloaded 438 times
Hope you find through. It's "1" for 1 year old and "24" for you guessed it. There are two babies, one for the wireframe, one for the build-mofifier. Then there are two adults, one containing the third baby as target to start from at frame 100, and one with an armature, taking over at 195 i think. That's because initially i planned to let the last character do something realistic, like being shocked due to nakedness etc. But 250 frames aren't enough for bells and whistles.
grinsegold
Re: New intro anim
Postby grinsegold » Thu Aug 10, 2017 8:08 am
Btw, it's CC 0. Be my guest ;)
grinsegold
Re: New intro anim
Postby joepal » Thu Aug 10, 2017 4:47 pm
Okay... new draft, now with grinsegold's morph. I still feel there's something missing, but we're getting there. :-)
new_intro_draft_02.mp4
(857.23 KiB) Downloaded 405 times
Re: New intro anim
Postby blindsaypatten » Thu Aug 10, 2017 7:18 pm
I think it has a bit of the first this happens, then this happens, then this happens. You might play with overlapping the parts a bit.
Re: New intro anim
Postby wolgade » Thu Aug 10, 2017 7:21 pm
Looks good. Is it intended to make the human appear a few frames later than the circle? Talking about the cherry on the pie: Why not make the "H" glow for a moment after it's apearance?
Re: New intro anim
Postby joepal » Thu Aug 10, 2017 8:04 pm
blindsaypatten wrote:I think it has a bit of the first this happens, then this happens, then this happens. You might play with overlapping the parts a bit.
Yeah, agreed. It should be more fluid in the transitions between activities.
