doodles and experiments
Re: doodles and experiments
Postby jujube » Fri Jun 08, 2018 1:42 am
RobBaer wrote:
jujube wrote:Blender 2.79b + denoising + Principled shader "random walk" subsurface + hdrihaven + basemesh + Hairtool
You can make braids with hairtool now
Your hair tool experiments keep intriguing me, but I haven't quite pulled the trigger on paying up. :D
In your image the back lighting seems to reveal some transparency artifacts with the "stringy hair". Is this an intrinsic fault of the tool, or just an unhappy circumstance of this particular scene and the lighting choices you made while playing?
It's not a hairtool thing, which only makes geometry not textures (well, there is a baking feature now, but i havent figured out how to use it yet). My alpha mask was just a handful of brush strokes in MS paint, lol. There's also the issue of transparent bounces. Hairtool tends to make tons of overlapping strands, and if you dont crank up the max transparent bounces (or some other glitch happens, like not clamping after increasing the contrast) then the transparent parts turn black.
(edit: I did a test render with transparent background, it seems the artifacts were caused by the white background. w/transparency, it's smoother.)
Stats and pics for satisfying curiosity:
Hdri used: pillars 16k https://hdrihaven.com/hdri/?h=pillars
30 max transparent bounces
Default denoising on.
I can also upload the hair mesh if anyone is interested.
alpha texture
"naked" hair geometry
Hair material
Postby jujube » Fri Jun 15, 2018 3:22 am
Human face next to 1cm (gray) and 1mm (red/blue) squares.
Image showing how at a far distance/lower resolution, you cant make out the details of the colored square.
Postby jujube » Mon Sep 17, 2018 1:04 am
In the development/bleeding-edge version of blender 2.79 you can "comb" cloth in the particle edit mode. The result is that the cloth falls into the shape that you sculpted it. The animation is of a square of cloth falling onto a perfectly average cube.
principled shader with sheen + hdrihaven car hdri = lovely shading
0001-0060.avi
(474.07 KiB) Downloaded 373 times
Postby wolgade » Tue Sep 18, 2018 10:00 am
jujube wrote:n the development/bleeding-edge version of blender 2.79 you can "comb" cloth in the particle edit mode.
Cool! It might get much easier to create realistic loose fitting clothes.
