instantmesh retopology
Posted:
Sat May 27, 2017 9:28 pm
by jujube
Right now I'm using Instant Meshes (link:
https://github.com/wjakob/instant-meshes) to turn models from BodyParts3d all-quad. I was going to put it inside the body but I should turn it into a prop, then someone can use it for a last-minute contest entry, heh.
Re: instantmesh retopology
Posted:
Sun May 28, 2017 1:58 am
by jujube
I finished my skull, so off to the repo it goes.
But now I have a question for LIndsay: is the amount of space between the lip and maxilla anatomically correct?
Posted:
Sun May 28, 2017 2:44 am
by blindsaypatten
I'm not going to claim to know that kind of anatomy so here is what Zygote Body(tm) shows:
The thing that sticks out to me is that the gums should cover the bones to a greater extent, although perhaps that would detract from observation of the bones.
Posted:
Sun May 28, 2017 8:45 pm
by jujube
I wrote about my technological difficulties with retopologizing but then google chrome ate my post. Well the point was that the topology is weird, I need a better topology tool, so just now I finished up my alpha 7 ear proxy instead and uploaded it to the repo. This is only the first version, the geometry is still kinda weird, including the fact that it's lumpy and jagged unless you subdivide it. This is because I fitted it to base.obj. Version two (which I'll probably do after writing this post) will be built on the startup mesh, hopefully fixing that. Well, the startup mesh, with ear targets applied to make it fit better with the alpha7 ear, and generally make the area surrounding the ear look less weird.
Posted:
Mon May 29, 2017 12:06 pm
by o4saken
Just quick from my side... i know that i talked about this before in the off topic section but Autodesks ReMake (was memento) - its free, up until a certain size mesh and some other things not included, but for most purposes it is free. Its main purpose is if you take a 360 photo of an object and run it through here it makes a perfect model of said object. However it comes with a whole lot of mesh fixing tools, mainly for purpose of 3d printing. but one of the tools is to convert all tris to quads. Now i cant use this because i cant load it onto my work pc, but i have seen this used, even some youtube videos. and it works well from what i have seen.
So if you looking for a retopo tool, give it a try. and Pls if you do some feedback for others battling with retopo.
Posted:
Mon May 29, 2017 5:16 pm
by jujube
I have a student account that I can use to install it, but sadly my computer doesn't want me to download it :/
Posted:
Mon May 29, 2017 5:48 pm
by jujube
It has simultaneously completed installation AND failed to install some objects! I
love this kind of choice bullshit!!
thanks for getting my hopes up o4saken
Posted:
Mon May 29, 2017 8:15 pm
by jujube
I got it installed now... sorry for being a bitch
