Normal and Occlusion Maps
Re: Normal and Occlusion Maps
Postby o4saken » Wed Oct 24, 2018 6:32 am
blindsaypatten wrote:Thanks for the tips!
Btw, the principled shader is available in the recent builds of 2.79. Certainly an easier upgrade than 2.8 which will break lots of MH stuff.
oh i got that wrong then - just checked work is version 2.78 - home in 2.79 which you are correct has the principled.
Postby o4saken » Wed Oct 24, 2018 1:24 pm
Ladys hairstyle
Finally managed to create a hair style that i think is pretty decent - its still not perfect, but its much better than my previous attempts - actually working on this one i could see what i was doing wrong - so if i get the energy to make a different one i am pretty sure it will be even better. But to be honest hair is a lot of work for something that i would never use myself.
this has a black and white image - like most of my stuff - that is used for the factor of the transparents mix shader node.
ladysmedhair.zip
(2.77 MiB) Downloaded 407 times
Postby o4saken » Thu Nov 01, 2018 12:30 pm
Medium blonde hair
Decided to give another hairstyle an attempt
so here is the reference that i kinda went for:
And here is the result:
I do really like the way it came out - but its definitely not low poly, in order to get smooth curly hair i had to subdivide the mesh quite a bit.
doing a straight hairstyle would be much easier.
I have included a dark brown hair texture as well, and there is the Black and white texture that i use for the factor of the transparent mix shader node.
mediumblondehair.zip
(16.9 MiB) Downloaded 416 times
