Normal and Occlusion Maps
Re: Normal and Occlusion Maps
Postby grinsegold » Fri Mar 17, 2017 1:15 pm
I downloaded your "floral". I changed the tags in the mhclo file from your name to "Female" and "Shirt", and in the mhmat file i filled in the textures:
// Textures and properties
...and i enabled them further down the script:
// Configure built-in shader defines
shaderConfig diffuse true
shaderConfig bump true
shaderConfig normal true
I also added a thumbnail (change the filetype manually from ".png" to ".thumb"):
grinsegold
Postby grinsegold » Fri Mar 17, 2017 1:21 pm
I wasn't able to implement your ao-map, since i still haven't found a documentation on the right naming and calling of textures in MH. But i'm almost sure that there is no genuine ao-slot. Maybe one has to overlay the ao-map in gimp onto the diff...
grinsegold
Postby o4saken » Fri Mar 17, 2017 1:28 pm
How do you edit these files manually? i know it is a text file basically, but i had tried once to edit it and re save the file using a text editor but then after the file just didnt work.
Postby grinsegold » Fri Mar 17, 2017 1:44 pm
o4saken wrote:How do you edit these files manually? i know it is a text file basically, but i had tried once to edit it and re save the file using a text editor but then after the file just didnt work.
Try it again. If someone like me is able to manage that, than you can surely as well. Maybe changing from MS to Linux helps ;)
grinsegold
Postby o4saken » Fri Mar 17, 2017 1:46 pm
grinsegold wrote: Maybe changing from MS to Linux helps ;)
Therein lies the problem i am guessing.
Postby grinsegold » Fri Mar 17, 2017 1:49 pm
here are the two other missing thumbnails
grinsegold
Postby Aranuvir » Fri Mar 17, 2017 3:09 pm
Here is a list of all possible keywords and values from material.py , hopping this is helpful:
"name": string
"tag": string
"description": string
"ambientColor": 3 x float
"diffuseColor": 3 x float
"specularColor": 3 x float
"shininess": 1 x float
"emissiveColor": 3 x float
"opacity": 1 x float
"translucency": 1 x float
"shadeless": bool
"wireframe": bool
"transparent": bool
"alphaToCoverage": bool
"backfaceCull": bool
"depthless": bool
"castShadows": bool
"receiveShadows": bool
"autoBlendSkin": bool
"diffuseTexture": filename
"bumpmapTexture": filename
"bumpmapIntensity": 1 x float
"normalmapTexture": filename
"normalmapIntensity": 1 x float
"displacementmapTexture": filename
"displacementmapIntensity": 1 x float
"specularmapTexture": filename
"specularmapIntensity": 1 x float
"transparencymapTexture": filename
"transparencymapIntensity": 1 x float
"aomapTexture": filename
"aomapIntensity": 1 x float
"sssEnabled": bool
"sssRScale": 1 x float
"sssGScale": 1 x float
"sssBScale": 1 x float
"shader": filename
"uvMap": filename
"shaderParam": ['diffuse', 'ambient', 'specular', 'emissive', 'diffuseTexture', 'bumpmapTexture', 'bumpmapIntensity', 'normalmapTexture',
                'normalmapIntensity', 'displacementmapTexture', 'displacementmapTexture', 'specularmapTexture', 'specularmapIntensity',
                'transparencymapTexture', 'transparencymapIntensity', 'aomapTexture', 'aomapIntensity']
"shaderDefine": ['BUMPMAP', 'NORMALMAP', 'DISPLACEMENT', 'SPECULARMAP', 'TRANSPARENCYMAP']
"shaderConfig"  "diffuse": bool
                "bump": bool
                "normal": bool
                "displacement": bool
                "spec": bool
                "vertexColors": bool
                "transparency": bool
                "ambientOcclusion": bool
Floats are between 0.0 and 1.0
I don't know much about the shader thing and how to use the parameters. Perhaps someone of the devs can help out.
Postby grinsegold » Fri Mar 17, 2017 3:43 pm
oh yeah, i guess this one is pretty useful. THX!
grinsegold
Postby grinsegold » Fri Mar 17, 2017 4:02 pm
Aranuvir wrote:Here is a list of all possible keywords and values from material.py , hopping this is helpful:
I added this to the documentation:
http://www.makehumancommunity.org/wiki/ ... rial_files
grinsegold
Postby joepal » Fri Mar 17, 2017 4:12 pm
Also, the asset editor plugin will help you significantly if you want to adjust asset files. Then you don't need to modify them by hand.
