Page 1 of 32
Normal and Occlusion Maps
Posted:
Sun Jan 10, 2016 9:45 am
by o4saken
I decided that i want to learn to make normal maps, experiment arround with different methods, and see what i get. Hopefully in the end to be able to make some awesome assets.
Anyhow, first attempt was my more detailed male model skin texture, and then i decided to try it out on the elegant male suit.
I am posting this as work in progress as i will be adding more as i go along.
Here is the normal map/ occlusion map for the suit for anyone who is interested, as well as render examples with and without it. I set the normal map to strength 1.5, which is a bit strong but i wanted to see the difference.
Re: Normal and Occlusion Maps
Posted:
Sun Jan 10, 2016 10:54 am
by duststorm
Nice
If I remember correctly, those MH assets also already include AO and normal maps of their own, though I can't remember how they looked.
Posted:
Sun Jan 10, 2016 12:03 pm
by o4saken
duststorm wrote:Nice
When i used the shorts it exported a normal map which was fantastic, but when i chose the suit for a design i was working on it only came with the difuse, thus i created my own. not sure if there is one, but i assume it would have exported were there one.
Posted:
Sun Jan 10, 2016 12:24 pm
by duststorm
There are AO maps for the suits:
http://download.tuxfamily.org/makehuman ... t01_ao.pngWhy they are not exported, no idea. The AO map is declared in the mhmat file as far as I can see.
EDIT: My bad, that was the casual suit ...
Indeed, elegant suit has no AO map:
http://download.tuxfamily.org/makehuman ... antsuit01/
Posted:
Mon Jan 11, 2016 1:25 pm
by o4saken
My first attempt at makeclothes, thus i went with a simple t shirt.
I am not sure if the texture actually exported, thus i have included it in the zip folder along with a Normal and AO map.
Posting it here and not under user contributions as its nothing special and i plan on creating better stuff that i will upload to there.
CLOTHES HAVE BEEN MOVED TO USER CONTRIBUTIONS
Posted:
Mon Jan 11, 2016 4:37 pm
by duststorm
Indeed the material file does not reference the textures.
A quick tip: if you enable the material editor plugin in makehuman, and restart, you can modify the material from there.
To fix the material, add the following lines at the bottom (to the .mhmat file):
- Code: Select all
Posted:
Tue Jan 12, 2016 6:05 am
by o4saken
Hmm that is what i thought, but i dont understand why as i had it all set up prior to clicking makeclothes button. not sure what i am doing wrong then.
Posted:
Tue Jan 12, 2016 2:16 pm
by o4saken
OK i need help, i am trying to make a jacket, but when i try to makeclothes it says that it cant as i have both tris and quads... Now i know you cant use tris which is why i was carefull not to get any.. i have rechecked and there really arent any.. its all squares, so why am i getting this error?
Posted:
Tue Jan 12, 2016 2:28 pm
Are you sure you don't have a surface with
more than four edges?
I didn't try (I'm at the office), but there seems to be a key combo for selecting all quad faces. If you do that and invert, is anything selected?
Really old docs though (scroll down to "face types") :
http://wiki.blender.org/index.php/Doc:2 ... ting/Faces
Posted:
Tue Jan 12, 2016 3:10 pm
by learning
I usually use
http://wiki.blender.org/index.php/Exten ... g/MeshLint for this. It can find both tris and ngons as well as other mesh irregularities that are probably not so relevant to MH but still are worth knowing of.
