wolgade wrote:
This is unfinished business, but I'll post it anyway to show what I'm talking about. I started to create another ponytail with less thickness at the ring. I used 200 hairs to start with, but then deleted all hairs except those on the edge of the scalp.
The second particle system uses interpolated children which work well in this case.
Hmm, a lot of new experiences. If this works better, we should put the results into the strand hair thread (and create something like a tutorial, but we both are still learning).
I started manually with 100 hairs (only one half because of mirroring). I didn't even know if mirroring works, but it did fortunately. But one paramerter is always interesting: the number of segments for hair, because after working with the hair you can't change this without loosing all the work. I took only 8 segments, you seem to use a lot more.
I had the same approach in a way. First I designed all hair going through the ring. And then I decided to delete half of the hair (or shorten it) so it looks like it will only go in the direction of the rings. And I regret not to take an additional particle system because these short strands have the same color pattern like the pig tails so I hide part of the ends in the skull. For the frontal long hair strands I took an additional particle system, and even that was not a good idea, I should have taken two systems. So maybe a solution with 6 particle systems is the best. For each side: one for the pigtails, one for the hair directly going to the pigtails and one for the frontal strands. For posing you comb the pigtails and the frontal strands.
On the other hand: did Harley Quinn really comb her hair?!
