Platter Tutu need help
Postby badwolf » Wed Oct 14, 2015 12:40 am
https://dl.dropboxusercontent.com/u/5398233/ptutu2.zip
my problem is if you move the age off "average" it distorts badly any advise on how to fix??
i do realize this is a pathological example (edge is way off the model)
badwolf
Re: Platter Tutu need help
Postby MTKnife » Sun Nov 01, 2015 6:09 am
I see what you mean--and I've had similar problems with the waistline of a mini-skirt, though I didn't realize until I read this post that the problem only showed up on younger figures.
In general, the age slider seems to have problems: it works OK if you adjust age before doing anything else, but if you make any other changes to the body (say, breast size), adjusting age afterwards can produce bizarre results.
MTKnife
Postby badwolf » Sun Nov 01, 2015 12:23 pm
the fitting algo does not have a documented way to handle anything off the body
badwolf
Postby MTKnife » Mon Nov 02, 2015 1:01 am
The problems seem to occur at the waistline, though. Fix that and the rest may follow.
MTKnife
Postby badwolf » Mon Nov 02, 2015 10:01 pm
MTKnife wrote:The problems seem to occur at the waistline, though. Fix that and the rest may follow.
yeah HOW is the problem.
the dodge is if i try to setup vert groups then i get doubled groups or the script goes BANG
badwolf
