Body Suit Shoulder Holster
Postby brkurt » Tue Jan 20, 2015 10:46 pm
Hello everyone...I'm going to need help with this one, so that it can be added to the clothing library.
It's the beginning of a complete body suit and shoulder holster that will fit under the new stylish suit.
The gun would be a 'Lady Glock (model 27)':
with two extra clips:
the chemise would be carbon fibre, cover from neck to groin when complete.
You can try the model yourself; it is the very latest nightly build of 1.1
http://www.geekopolis.ca/blender/bodySu ... 266a.blend
Re: Body Suit Shoulder Holster
Postby brkurt » Thu Feb 05, 2015 5:34 pm
Here is the model with the new suit. Note that I have mirrored the buttons (standard for female clothes) and removed the shirt and tie.
I will be streamlining the model, but I want to rig it first before I do.
and a wireframe of the same:
You can try this model yourself, but it is very preliminary:
http://www.geekopolis.ca/blender/bodySuitShoulderHolster1_266a.blend
Postby brkurt » Mon Feb 16, 2015 5:23 pm
And now to apply the Cloth Modifier. I downloaded the Feb 15 2015 build. to make sure I had the latest rig. I've added my custom harness, and simplified the new male suit, but otherwise everything else is out-of-the-box.
I then separated out the jacket, and added a cloth modifier to it, for 100 frames. This is frame 80.
I converted this frame into a shape key. Be sure to back up your clothes meshes when you do this!
And here is a short video of same:
http://youtu.be/0E1ymZa8rqc
The model is fully rigged, so you can try it yourself.
For the techies: the materials used are electro-active shape memory polymers; the gun harness is also a gel battery, which accounts for its thickness.
http://www.geekopolis.ca/blender/bodySuitShoulderHolster1_273a.blend
Postby devrich » Tue Feb 17, 2015 7:20 am
Hey you're doing a great job here! :D
Don't settle for what someone else made -- upPIC your own [:.:] at: http://DevRich78.com/upPIC
devrich
