particle hair wip
particle hair wip
Postby NewArt2000 » Fri Oct 10, 2014 6:26 am
just messing around with a model using the mhx2 tool just put a little particle hair and some texture tweaks very much a work in progress. image took 4 min to render. I didn't do anything to the t-shirt. I need to figure out something with the eye textures. Any thoughts or opinions of the image welcomed it a WIP?
NewArt2000
Re: particle hair wip
Postby SaltyCowdawg » Sat Oct 11, 2014 12:42 am
how did you get the hair nice a curly like that. I've tried a few times and failed miserably...
Postby NewArt2000 » Tue Oct 14, 2014 1:04 am
SaltyCowdawg wrote:how did you get the hair nice a curly like that. I've tried a few times and failed miserably...
hair is tricky but in the children setting you have to play with clump value and shape value. after you get desired style.
NewArt2000
Postby SaltyCowdawg » Tue Oct 14, 2014 1:16 pm
I think I get it: comb first, add curl, clump and shape last. What radius and frequency values?
Postby NewArt2000 » Tue Oct 14, 2014 2:28 pm
SaltyCowdawg wrote:I think I get it: comb first, add curl, clump and shape last. What radius and frequency values?
these are the settings I used but I believe in some instances it will be a trail an error moment to get the look you want.
NewArt2000
