MH2UE4u
Re: MH2UE4u
Postby [Sandy] » Tue Nov 24, 2020 12:50 pm
MrGoatsy wrote:
nomorecookies wrote:What is the exact error?
Did you rename your armature to Armature?
Did you use the Game Engine skeleton and not one of the others?
I didn't know what armature was, but I figured it out.
I'm glad that the problem was solved.
You need to rename the armature object to "Armature". Problems may occur if you import characters into additional scenes that are not the default scenes. Post the modified script. Thanking for pointing that out.
[Sandy]
mh2ue.py
Postby [Sandy] » Tue Nov 24, 2020 12:54 pm
import bpy
import mathutils
bpy.ops.outliner.orphans_purge()
obj='Armature'
bpy.ops.object.mode_set(mode='OBJECT')
bpy.ops.object.select_all(action='DESELECT')
bpy.context.view_layer.objects.active = bpy.data.objects[obj]
bpy.ops.object.mode_set(mode='EDIT')
bones=[#edit bone(name, vector, roll)
    ('pelvis', (0.0, -0.0355, 9.7054), 1.204043940106203e-07),
    ('spine_01', (0.0, -2.4676, 19.0955), 1.2043376784731663e-07),
    ('spine_02', (0.0, 1.5651, 13.3223), 1.2037928343033855e-07),
    ('spine_03', (0.0, 2.3111, 13.8404), 1.2036994689879066e-07),
    ('clavicle_l', (13.9182, 6.9506, -2.671), 1.6761107444763184),
    ('upperarm_l', (9.9434, 1.1179, -11.7326), 2.410767078399658),
    ('lowerarm_l', (14.7201, -8.7915, -11.2146), 2.0401418209075928),
    ('hand_l', (7.4183, -4.7717, -6.2159), 0.7742447257041931),
    ('index_01_l', (1.6298, -1.3284, -3.7365), 1.688023328781128),
    ('index_02_l', (0.7641, -0.6676, -3.2386), 1.9376062154769897),
    ('index_03_l', (1.1548, -1.0154, -3.0254), 1.7928578853607178),
    ('middle_01_l', (2.0408, -1.2455, -3.9771), 1.37657630443573),
    ('middle_02_l', (0.9041, -0.8173, -3.4393), 1.6097930669784546),
    ('middle_03_l', (1.8408, -0.8, -3.0472), 1.26283860206604),
    ('pinky_01_l', (1.9121, -0.2855, -3.0024), 0.8965443968772888),
    ('pinky_02_l', (1.0753, -0.228, -2.7759), 1.1303706169128418),
    ('pinky_03_l', (1.0301, -0.4317, -2.7689), 1.1524299383163452),
    ('ring_01_l', (2.0167, -0.8928, -3.8422), 1.0971653461456299),
    ('ring_02_l', (0.8418, -0.5747, -3.3239), 1.3844847679138184),
    ('ring_03_l', (1.5493, -0.785, -3.0117), 1.1123979091644287),
    ('thumb_01_l', (0.1295, -3.2002, -2.1717), -2.6270177364349365),
    ('thumb_02_l', (0.1767, -2.4893, -3.2052), -2.6139678955078125),
    ('thumb_03_l', (-0.3584, -2.9914, -2.7248), -2.2586119174957275),
    ('clavicle_r', (13.9182, -6.9506, 2.671), -1.8446810245513916),
    ('upperarm_r', (9.9435, -1.1179, 11.7327), -2.4663352966308594),
    ('lowerarm_r', (14.7202, 8.7916, 11.2146), -2.40354061126709),
    ('hand_r', (7.4183, 4.7717, 6.2159), 2.52095627784729),
    ('index_01_r', (1.6298, 1.3285, 3.7367), 2.510608673095703),
    ('index_02_r', (0.7641, 0.6676, 3.2386), 2.400984048843384),
    ('index_03_r', (1.1548, 1.0154, 3.0254), 2.5221238136291504),
    ('middle_01_r', (2.0409, 1.2455, 3.9772), 2.3247838020324707),
    ('middle_02_r', (0.9042, 0.8173, 3.4393), 2.1239285469055176),
    ('middle_03_r', (1.8408, 0.8, 3.0473), 2.3496832847595215),
    ('pinky_01_r', (1.9122, 0.2855, 3.0024), 2.030719757080078),
    ('pinky_02_r', (1.0752, 0.228, 2.7757), 1.8695118427276611),
    ('pinky_03_r', (1.03, 0.4316, 2.7686), 1.8647516965866089),
    ('ring_01_r', (2.0165, 0.8928, 3.8419), 2.0638554096221924),
    ('ring_02_r', (0.8418, 0.5747, 3.3239), 1.8805898427963257),
    ('ring_03_r', (1.5493, 0.785, 3.0117), 2.062621593475342),
    ('thumb_01_r', (0.1295, 3.2001, 2.1717), -2.507920503616333),
    ('thumb_02_r', (0.1767, 2.4893, 3.2052), -2.5038182735443115),
    ('thumb_03_r', (-0.3584, 2.9914, 2.7248), -2.5201525688171387),
    ('neck_01', (0.0, -2.2521, 9.0137), 1.2046517383623723e-07),
    ('head', (0.0, 0.2141, 9.2883), 1.203985817710418e-07),
    ('thigh_l', (-3.9585, -0.9659, 32.0754), 0.022982334718108177),
    ('calf_l', (-2.1573, -4.7335, 29.8874), -0.019580373540520668),
    ('foot_l', (-0.2906, -0.2511, 19.5951), 0.030697213485836983),
    ('ball_l', (0.9077, -19.5579, -0.8815), -1.5856081247329712),
    ('thigh_r', (-3.9585, 0.9659, -32.0755), 0.268565833568573),
    ('calf_r', (-2.1573, 4.7335, -29.8876), 0.12452912330627441),
    ('foot_r', (-0.2906, 0.2511, -19.595), 0.060352873057127),
    ('ball_r', (0.9077, 19.5579, 0.8815), 0.014443517662584782),
arm=bpy.data.armatures[0]
for bone in bones:
    arm.edit_bones[bone[0]].tail=\
        arm.edit_bones[bone[0]].head+mathutils.Vector(bone[1])
    arm.edit_bones[bone[0]].roll=bone[2]
[Sandy]
Re: MH2UE4u
Postby MrGoatsy » Wed Nov 25, 2020 5:02 pm
I got most animations to work fine, however a few like rolling don't work.
This is how it is supposed to look:
https://i.imgur.com/NB71nej.gifv
This is how it looks with the mesh:
https://i.imgur.com/JCMirR6.gifv
https://drive.google.com/file/d/1EiJzwl ... p=drivesdk
In both images they use the same skeleton.
All other animations pretty much look exactly the same except climbing a ladder which is also messed up, I assume once I fix the rolling the ladder animation will also be fixed.
How do I fix this?
MrGoatsy
Re: MH2UE4u
Postby MrGoatsy » Wed Nov 25, 2020 6:53 pm
nomorecookies wrote:Sadly i have been unable to find a solution to the 'anchor' problem. Many, Many attempts. including or not including body parts, hair, etc. nothing is fixing it.
Perhaps the code that is posted on this page is slightly different than what you have locally on your computer?
Maybe you could post the script again, just to make sure.
Thank you
I used the script from this page.
It is weird though, most animations are fine, only a few are messed up.
MrGoatsy
Re: MH2UE4u
Postby [Sandy] » Thu Nov 26, 2020 3:54 pm
Are you talking about ALS rolling? In the ALS description section of the epic marketplace, it says:
IMPORTANT: IT IS HIGHLY ADVISED THAT YOU HAVE A GOOD UNDERSTANDING OF BLUEPRINTS AND ARE FAMILIAR WITH HOW GAME ANIMATION WORKS PRIOR TO YOUR PURCHASE OF THIS PACK. THIS IS NOT A PLUG AND PLAY SYSTEM, AND WORKING WITH IT CAN BE CONFUSING IF YOU ARE NEW TO UE4.
Also personally, I'm using Unreal Engine 4.23 and the ALS version is 3.I will do additional research, but it may take some time.
[Sandy]
Re: MH2UE4u
Postby [Sandy] » Fri Nov 27, 2020 2:38 pm
The problem was solved more easily than I expected. I was able to solve it by rotating the Root bone.
[Sandy]
mh2ue.py
Postby [Sandy] » Fri Nov 27, 2020 2:40 pm
import bpy
import mathutils
obj='Armature'
    ('Root', (3.14, 0.0, 0.0), 1.57),
for bone in bones:
[Sandy]
Re: MH2UE4u
Postby MrGoatsy » Sat Nov 28, 2020 6:46 pm
[Sandy] wrote:Are you talking about ALS rolling? In the ALS description section of the epic marketplace, it says:
I was not.
MrGoatsy
Re: mh2ue.py
Postby MrGoatsy » Sat Nov 28, 2020 9:21 pm
[Sandy] wrote:
import bpy
import mathutils
obj='Armature'
for bone in bones:
This also fixed it, however when I put armour on my character the lower arm part gets messed up, when I use the other method I used previously it doesn't warp the lower arm part.
MrGoatsy
Re: MH2UE4u
Postby [Sandy] » Mon Nov 30, 2020 12:58 pm
Q1: If I export a naked character, does it work fine by replacing it with a third person template character or an ALS4 character?
Q2: What is "armour"? Is it a make-human asset?
Q3: What is the "other method"?
I exported a character wearing long-sleeved clothes and replaced it with a third person template character or ALS4 character, but it seems that there is no particular problem.
[Sandy]
Return to Tutorials
