import bpy
import mathutils
bpy.ops.outliner.orphans_purge()
obj = "Armature"
arm = bpy.data.armatures[0]
bpy.ops.object.mode_set(mode='OBJECT')
bpy.ops.object.select_all(action='DESELECT')
bpy.context.view_layer.objects.active = bpy.data.scenes[0].objects[obj]
bpy.ops.object.mode_set(mode='EDIT')
bones = [
("pelvis", (0.0000, -0.0355, 9.7054), 1.204043940106203e-07),
("spine_01", (0.0000, -2.4676, 19.0955), 1.2043376784731663e-07),
("spine_02", (0.0000, 1.5651, 13.3223), 1.2037928343033855e-07),
("spine_03", (0.0000, 2.3111, 13.8404), 1.2036994689879066e-07),
("clavicle_l", (13.9182, 6.9506, -2.6710), 1.6761107444763184),
("upperarm_l", (9.9434, 1.1179, -11.7326), 2.410767078399658),
("lowerarm_l", (14.7201, -8.7915, -11.2146), 2.0401418209075928),
("hand_l", (7.4183, -4.7717, -6.2159), 0.7742447257041931),
("index_01_l", (1.6298, -1.3284, -3.7365), 1.688023328781128),
("index_02_l", (0.7641, -0.6676, -3.2386), 1.9376062154769897),
("index_03_l", (1.1548, -1.0154, -3.0254), 1.7928578853607178),
("middle_01_l", (2.0408, -1.2455, -3.9771), 1.37657630443573),
("middle_02_l", (0.9041, -0.8173, -3.4393), 1.6097930669784546),
("middle_03_l", (1.8408, -0.8000, -3.0472), 1.26283860206604),
("pinky_01_l", (1.9121, -0.2855, -3.0024), 0.8965443968772888),
("pinky_02_l", (1.0753, -0.2280, -2.7759), 1.1303706169128418),
("pinky_03_l", (1.0301, -0.4317, -2.7689), 1.1524299383163452),
("ring_01_l", (2.0167, -0.8928, -3.8422), 1.0971653461456299),
("ring_02_l", (0.8418, -0.5747, -3.3239), 1.3844847679138184),
("ring_03_l", (1.5493, -0.7850, -3.0117), 1.1123979091644287),
("thumb_01_l", (0.1295, -3.2002, -2.1717), -2.6270177364349365),
("thumb_02_l", (0.1767, -2.4893, -3.2052), -2.6139678955078125),
("thumb_03_l", (-0.3584, -2.9914, -2.7248), -2.2586119174957275),
("clavicle_r", (13.9182, -6.9506, 2.6710), -1.8446810245513916),
("upperarm_r", (9.9435, -1.1179, 11.7327), -2.4663352966308594),
("lowerarm_r", (14.7202, 8.7916, 11.2146), -2.40354061126709),
("hand_r", (7.4183, 4.7717, 6.2159), 2.52095627784729),
("index_01_r", (1.6298, 1.3285, 3.7367), 2.510608673095703),
("index_02_r", (0.7641, 0.6676, 3.2386), 2.400984048843384),
("index_03_r", (1.1548, 1.0154, 3.0254), 2.5221238136291504),
("middle_01_r", (2.0409, 1.2455, 3.9772), 2.3247838020324707),
("middle_02_r", (0.9042, 0.8173, 3.4393), 2.1239285469055176),
("middle_03_r", (1.8408, 0.8000, 3.0473), 2.3496832847595215),
("pinky_01_r", (1.9122, 0.2855, 3.0024), 2.030719757080078),
("pinky_02_r", (1.0752, 0.2280, 2.7757), 1.8695118427276611),
("pinky_03_r", (1.0300, 0.4316, 2.7686), 1.8647516965866089),
("ring_01_r", (2.0165, 0.8928, 3.8419), 2.0638554096221924),
("ring_02_r", (0.8418, 0.5747, 3.3239), 1.8805898427963257),
("ring_03_r", (1.5493, 0.7850, 3.0117), 2.062621593475342),
("thumb_01_r", (0.1295, 3.2001, 2.1717), -2.507920503616333),
("thumb_02_r", (0.1767, 2.4893, 3.2052), -2.5038182735443115),
("thumb_03_r", (-0.3584, 2.9914, 2.7248), -2.5201525688171387),
("neck_01", (0.0000, -2.2521, 9.0137), 1.2046517383623723e-07),
("head", (0.0000, 0.2141, 9.2883), 1.203985817710418e-07),
("thigh_l", (-3.9585, -0.9659, 32.0754), 0.022982334718108177),
("calf_l", (-2.1573, -4.7335, 29.8874), -0.019580373540520668),
("foot_l", (-0.2906, -0.2511, 19.5951), 0.030697213485836983),
("ball_l", (0.9077, -19.5579, -0.8815), -1.5856081247329712),
("thigh_r", (-3.9585, 0.9659, -32.0755), 0.268565833568573),
("calf_r", (-2.1573, 4.7335, -29.8876), 0.12452912330627441),
("foot_r", (-0.2906, 0.2511, -19.5950), 0.060352873057127),
("ball_r", (0.9077, 19.5579, 0.8815), 0.014443517662584782)
for bone in bones:
arm.edit_bones[bone[0]].tail = arm.edit_bones[bone[0]].head + mathutils.Vector(bone[1])
arm.edit_bones[bone[0]].roll = bone[2]
nomorecookies wrote:Wow! that is pretty cool!
nomorecookies wrote:the UEFY script has a pose mechanic built in.
[Sandy] wrote:1.1. Pose/Animate - Skeleton: Game engine
nomorecookies wrote:I see what you mean about the pose though. it seems it was posed to compensate for the hunchback, but really, it should not be. that causes other animations to be leaned back. for example, the generic NPC anim pack. if you look at any of those, you can see they are leaned back the exact amount of the original pose compensation.
nomorecookies wrote:I am having a strange issue aside from all of that. there is a thing coming from the top of the spine of my character, all the way to the floor. it is like the type of problems you get when you forget to set the retargeting iptions in different scenarios. i did everything per instructions, and assigned directly to the ue4 mannequin skeleton. everything works great, just that strange extension from the back top of the spine, about a 45 degree angle, all the way to the floor.
Are you using UEFY? The python script I wrote assumes that you use makehuman game engine skeleton.
"Apose_ue" is applied to correct the difference between makehuman's A pose and Unreal's A pose. I'm checking using third-person animations, anim starter packs, MCO_MOCAP Basics, but do you think these animations are also weird?
Does this behavior occur even with naked characters? Or does it happen when you wear certain clothes? If you experience any symptoms with a particular garment, what is the name of the garment? It may be useful for investigating the cause.
I hope your problem will be solved.
