Quick and easy fix for mangled knee joints
Postby blindsaypatten » Wed Jul 12, 2017 12:35 am
Credit to jujube for posting the link to the tension map video in the muscles thread where I found this method!
If you have done much posing of MakeHuman characters you know that some joints get mangled when bent, forming a crease on the side of the joint that is compressing, for example knees:
Just add a Corrective Smoothing modifier to the body:
And presto! Much improved bending action:
Here's an animated demo:
https://youtu.be/JgYy80TiVGk
You can use a vertex group if you only want to apply the modifier to a particular joint or want to use different Repeat values for different joints.
Edit:
Ah, I knew it was too good to be true.
It does a nice job on the shoulder:
This:
becomes:
but clothing doesn't keep up:
Well, I guess there is still cloth simulation to deal with that...
Re: Quick and easy fix for mangled knee joints
Postby jujube » Sat Jul 15, 2017 11:48 pm
That shoulder looks a lot better, I should try using this with makewalk.
Postby Mindfront » Tue Jul 25, 2017 1:46 pm
Thank you!
I always use the Corrective Smooth modifier on my characters and some of the clothes but of some unclear reason I never thought of testing a greater value than 1 on repeat.
Now I have weight painted all areas that needs to be adjusted and suddenly posing looks much better than ever.
Mindfront
Return to Tutorials
